need to activate 4 servo motors based on load cell data
Need to activate four servo motors based on load cell data for development of weight base grader.
I'm new for this for I tried my best and created a programme.
On LCD it showing the exact weight but the servo motors are getting fluctuations.
can you please help by checking the below mentioned programme..
#include <Servo.h>
#include <HX711_ADC.h>
#include <Wire.h>
#include <LiquidCrystal.h>
HX711_ADC LoadCell(3, 2);
Servo myservo1;
Servo myservo2;
Servo myservo3;
Servo myservo4;
float calibration_factor = 135; // this calibration factor is adjusted according to my load cell
float units;
float ounces;
LiquidCrystal lcd(12, 11, 7, 6, 5, 4);
LoadCell.begin();
LoadCell.start(2000.10);
LoadCell.setCalFactor(399.30);
myservo1.attach(8); //servo pins digital
myservo2.attach(9);//servo pins
myservo3.attach(10);//servo pins
myservo4.attach(13);//servo pins
//scale.set_scale();
//scale.tare(); //Reset the scale to 0
//long zero_factor = scale.read_average(); //Get a baseline reading
//Serial.print("Zero factor: "); //This can be used to remove the need to tare the scale. Useful in permanent scale projects.
//Serial.println(zero_factor);
lcd.begin(16, 2);
LoadCell.update();
float i = LoadCell.getData();
Serial.println ("i");
lcd.setCursor(0, 0);
lcd.print("Weight[g]:");
lcd.setCursor(0, 1);
lcd.print(i);
// scale.set_scale(calibration_factor); //Adjust to this calibration factor
Serial.print("Reading: ");
//units = scale.getData(), 10;
if (i < 0)
i = 0.00;
ounces = i * 0.035274;
Serial.print(i);
Serial.print(" grams");
Serial.print(" calibration_factor: ");
Serial.print(calibration_factor);
if (i >100 && i <105)
myservo1.write(180); // if weight is more than 100 gm then servo motor move 180 degree anti clockwise
delay(5); // waits 15ms for the servo to reach the position
myservo1.write(-180);
if (i > 105 && i <110) // if weight is more than 105 gm then servo motor move 180 degree clockwise
myservo2.write(180); // tell servo to go to position in variable 'pos'
myservo2.write(-180);
if (i > 110 && i <115) // if weight is more than 110 gm then servo motor move 180 degree clockwise
myservo3.write(180); // tell servo to go to position in variable 'pos'
myservo3.write(-180);
if (i > 115 && i <120) // if weight is more than 115 gm then servo motor move 180 degree clockwise
myservo4.write(180); // tell servo to go to position in variable 'pos'
myservo4.write(-180);
delay(5);
lcd.print("Weight(g)="); // Weight print in lcd
lcd.println(i);
Start by Auto formatting your code in the IDE to improve its layout then posting it here using code tags (</> icon, top left of the edit window here) or Edit/Copy for forum in the IDE, to prevent the code being interpreted as HTML commands. Do you see the smiley in the code in your original post ?
As to your problem, I see this in your code (note what it looks like in code tags)
  if (i > 100 && i < 105)
The comments make no sense, but I know where they came from, and writing -180 to a servo is invalid as the range of values is 0 to 180. What are you trying to make the servo do at that point ? What type of servos do you have and how are they powered ?
This code looks as if you have deliberately designed the flutcuations
Move the servo, wait 5 millisecs and then move it back. And note that your comment is wrong. (And as pointed out in Reply #2, -180 is wrong)
You need to provide a better description of what actually happens and what you want to happen that is different.
And I have no idea what "weight base grader" means.
...R
PS ... To make it easy for people to help you please modify your post and use the code button </>
so your code looks like this
and is easy to copy to a text editor. See How to use the Forum
Thanks bob and robin for your immediate action,
If -ve angle is not considered, can you tell me how the motor comes to its original position after rotation of 180 with an example code if possible
RC control frames are 20ms long.
Nothing at all will happen in 5ms.
Take a look at the Sweep example, which judging by the comments in your code (which actually do not match the code),
you already have
What type of servos do you have ? Are they actually servos or are they continuous rotation "servos" which are not really servos at all ?
