I googled around but could not find an answer to my problem.
I have a need to convert a binary number from a string into an actual BIN and ultimately HEX datatype.
The code I’m using goes through a loop and does various test conditions on different integers, and if the difference between the integers is under a certain value, then that binary bit position is a zero, if over, then it’s a 1. So what I was thinking I needed to do was build a string representing the final binary number but I don’t know how to convert that string into an actual BIN or HEX number (HEX is the ultimate desired result).
So for example: The String might look like this “1011010110011001”
I just threw this together. If it doesn’t work it should be close.
unsigned long BinaryStringToUnsignedLong(String value)
unsigned long result = 0;
for (int i = 0; i < value.length; i++)
result <<= 1;
if (value[i] == '1')
result |= 1;
return result;
}[/code[
johnwasser:
For clarity, I had to make one correction - value.length needed parentheses
Here is the working code:
for (int i = 0; i < value.length(); i++)
result <<= 1;
result |= 1;
return result;
@EasyGoing1, how did the binary data get into a String object in the first place? Do you have any control over that processes / protocol? If so, you'd be well-advised to come up with something different. What you have now is highly inefficient.
