need to drive two dc motors at two diffrent speeds so far only one speed
hello I'm trying to control two different motors at two diffent speeds and was wondering if anyone could help me out right now I have one speed for both motors... here is my code...
#include <IRremote.h>
int RECV_PIN = 4;
IRrecv irrecv(RECV_PIN);
decode_results results;
int pinI1=8;//define I1 interface // UP DOWN MOTOR
int pinI2=11;//define I2 interface
int speedpinA=9;//enable motor A
int pinI3=12;//define I3 interface // FORWARD BACKWARD MOTOR
int pinI4=13;//define I4 interface
int speedpinB=10;//enable motor B
int spead =37;//define the spead of motor
irrecv.enableIRIn();
pinMode(pinI1,OUTPUT);// UP DOWN MOTOR
pinMode(pinI2,OUTPUT);
pinMode(speedpinA,OUTPUT);
pinMode(pinI3,OUTPUT);// FORWARD BACKWARD MOTOR
pinMode(pinI4,OUTPUT);
pinMode(speedpinB,OUTPUT);
if (irrecv.decode(&results)) {
irrecv.resume();
if (results.value == 0x827D40BF){ // forward
//SPEED
analogWrite(speedpinB,spead);
digitalWrite(pinI4,HIGH);
digitalWrite(pinI3,LOW);
}else if(results.value == 0x827DC03F){ // UP
analogWrite(speedpinA,spead);//SPEED
digitalWrite(pinI2,LOW);
digitalWrite(pinI1,HIGH);
else if(results.value == 0x827D807F){ // DOWN
digitalWrite(pinI2,HIGH);
digitalWrite(pinI1,LOW);
else if(results.value == 0x827D10EF){ // BACKWARD
analogWrite(speedpinB,spead);//SPEED
digitalWrite(pinI4,LOW);
digitalWrite(pinI3,HIGH);
else if(results.value == 0x827DA05F){ // STOP
digitalWrite(speedpinA,LOW);
digitalWrite(speedpinB,LOW);
I might not have understood 100% percent, but you could duplicate and modify this line:
thus:
int speadB =99;//define the spead of motorB
Then use "speadB" thus:
analogWrite(speedpinB,speadB);
(Note use of code tags to make code
look like this
Select code after you type it in and hit the </> icon top left.)
