Good day,
I need help running my code. Im trying out an automatic watering idea with humidity temp and lumens. When water goes below 60% it automatically will irrigate the pot. My codes a mess but I got it to work. What i need to do now is to read the data from sensors every 30 minutes or 1 hour and upload it via rpi. Any idea how can I do this. So technically my main concern is on the data to be read after every 30 minutes. here is my code
* Sensors - Setup and Test - LCD incorporated
* DHT-22 sensor (pin D4) to read temperature and humidity values
* LDR Sensor (Pin A0) used as luminosity Sensor ==> 0% full dark to 100% full light
* SoilSensor (Pin A1) used to read soil Moisture - Humidity
* ==> I2C LCD 4/20 for local monitoring (SDA ==> NANO Pin A4 SCL ==> NANO Pin A5)
* MJRoBot 21Aug16
// Include DHT Library
#include <DHT.h>
// Including Libraries for I2C LCD
#include <Wire.h>
// Sensor definitions
#define DHTPIN A3 // DHT data pin connected to Arduino pin 5
#define DHTTYPE DHT11 // DHT 22 (if your sensor is the DHT 11, only change this line by: #define DHTTYPE DHT11)
#define LDR_PIN A1 // used for Luminosity (LDR) Sensor Input
#define SOIL_MOIST_PIN A0 // used for Soil Moisture Sensor Input
#define SMS_VCC 7 // used for Soil Moisture Sensor "Power Supply" (VCC)
#define SMS_GND 6 // used for Soil Moisture Sensor "GND"
#define MOISTURE_SENSOR_INPUT_A 0//analog input of the moisture sensor
#define MOISTURE_SENSOR_INPUT_D 4//digital input of the moisture sensor(useless right now)
#define CALIB_POT_INPUT_A 0//Potentiometer(10k) input(analog)
#define WATER_SUPPLY_OUTPUT 5 // to turn ON the water pump(To TIP122)
#define DEFAULT_MAX_WATER_LEVEL 0.6 //default to fill upto
#define MOISTURE_REFRESH_INTERVAL 1 //moisture refresh interval for waterPlant() in seconds
#define DEBUG 1 //comment out during final compilation
// Variables to be used by Sensor
int tempDHT;
int humDHT;
int lumen;
int soilMoist;
// Initialize the DHT sensor
DHT dht(DHTPIN, DHTTYPE);
// Initialize LCD
LiquidCrystal_I2C lcd(0x27, 20, 4); // Set the LCD address to 0x27 for a 20 chars and 4 line display (use I2C scan to confirm address)
double getPotInputInPercent(); // to return the CALIB_POT input in percent
double getMoistSensorInputInPercent(); //to return the Moisture Sensor input in percent
void waterPlant(double toPercent); // to water the plant to the given moisture level
int period = 1000;
unsigned long time_now = 0;
Serial.println("Sensor readings");
delay(2000);
dht.begin();
lcd.begin ();//set the pump OFF by default
readSensors();
printData();
showDataLCD();
pinMode(SMS_VCC,OUTPUT);
pinMode(SMS_GND,OUTPUT);
pinMode(MOISTURE_SENSOR_INPUT_D,INPUT); //set pins as inputs and outputs
pinMode(WATER_SUPPLY_OUTPUT,OUTPUT);
digitalWrite(WATER_SUPPLY_OUTPUT,LOW);
double req_moisture_level = getPotInputInPercent(); //the value set on POT
double current_moisture = getMoistSensorInputInPercent();//get current moisture value
if(current_moisture < req_moisture_level )
{ //if the moisture level falls below the minimum required
waterPlant(req_moisture_level); //water the plants
void waterPlant(double toPercent = DEFAULT_MAX_WATER_LEVEL)
digitalWrite(WATER_SUPPLY_OUTPUT,HIGH); //turn the pump ON
double d = getMoistSensorInputInPercent();
while(d < toPercent)
{ //wait till the the moisture level reach the required minimum
delay(MOISTURE_REFRESH_INTERVAL*1000);
digitalWrite(WATER_SUPPLY_OUTPUT,LOW); //turn pump OFF
return analogRead(CALIB_POT_INPUT_A)/1023.0;
return 1 - analogRead(MOISTURE_SENSOR_INPUT_A)/1023.0;
}//the moisture sensor provides max val at minimum moisture level
* Read data from Sensors
void readSensors(void)
tempDHT = dht.readTemperature(); //Read temperature and humidity values from DHT sensor:
humDHT = dht.readHumidity();
lumen = getLumen(LDR_PIN);
soilMoist = getSoilMoist();
* Capture luminosity data: 0% full dark to 100% full light
int getLumen(int anaPin)
int anaValue = 0;
for(int i = 0; i < 10; i++) // read sensor 10X ang get the average
anaValue += analogRead(anaPin);
delay(50);
anaValue = anaValue/10; //Light under 300; Dark over 800
anaValue = map(anaValue, 1023, 0, 0, 100); //LDRDark:0 ==> light 100%
return anaValue;
* Capture soil Moisture data
int getSoilMoist()
int anaValue = 0;
digitalWrite(SMS_VCC,LOW); // drive a current through the divider in one direction
digitalWrite(SMS_GND,HIGH);
delay(1000); // wait a moment for capacitance effects to settle
anaValue += analogRead(SOIL_MOIST_PIN);
digitalWrite(SMS_VCC,HIGH); // reverse the current
digitalWrite(SMS_GND,LOW);
delay(1000); // give as much time in 'reverse' as in 'forward'
digitalWrite(SMS_VCC,LOW); // stop the current
anaValue = map(anaValue, 1023, 0, 0, 100); //xxx:0 ==> yyy 100%
return anaValue;
* Showing capured data at Serial Monitor
void printData(void)
Serial.print(" Temp DHT ==> ");
Serial.print(tempDHT);
Serial.print("oC Hum DHT ==> ");
Serial.print(humDHT);
Serial.print("% Luminosity ==> ");
Serial.print(lumen);
Serial.print("% Soil Moisture ==> ");
Serial.print(soilMoist);
Serial.println("%");
* Showing capured data at LCD
void showDataLCD(void)
lcd.setCursor (0,0);
lcd.print(" Control Station");
lcd.setCursor (0,1);
lcd.print(" ");
lcd.setCursor (0,2);
lcd.print("Temp: ");
lcd.print(tempDHT);
lcd.print("oC Hum: ");
lcd.print(humDHT);
lcd.print("% ");
lcd.setCursor (0,3);
lcd.print("Ligh: ");
lcd.print(lumen);
lcd.print("%");
lcd.print(" Soil: ");
lcd.print(soilMoist);
lcd.print("%");
