Need to limit a variable
Hey Guys,
I wrote a program here for determining the the color bands on a resister from 1 ohm to 999 ohms. The math in the program only works for between 1&999 ohms, but I can’t seem to figure out how to limit the variable R so that if anything below 1 or anything above 999 is enetered, that it instead displays an error message.
int Hplace;
int Tplace;
int Oplace;
int n;
int R;
int temp;
void setup(){
  Serial.println("Please enter a resister value");
void loop(){
 while (Serial.available() == 0){
  if (Serial.available() >= 0){
    R = Serial.parseInt();
      Hplace = (R/100);
      Tplace = (R/10) % 10;
      Oplace = R%10;
      Serial.print("A"); Serial.print(" "); Serial.print(R); Serial.print(" "); Serial.print("Ohm resistor has a color code of:");
      Serial.println("");
  for(n =1; n<=3; n++){
   if(n==1){
    temp = Hplace;
   else if(n==2){
     temp = Tplace;
    else{
     temp = Oplace;
    switch(temp){
         case 0:
           Serial.println("Black");
         case 1:
           Serial.println("Brown");
         case 2:
           Serial.println("Red");
         case 3:
         Serial.println("Orange");
         case 4:
         Serial.println("Yellow");
         case 5:
         Serial.println("Green");
         case 6:
         Serial.println("Blue");
         case 7:
         Serial.println("Violet");
         case 8:
         Serial.println("Gray");
         case 9:
         Serial.println("White");
OK i’ve split the action of getting input into it’s own function. Here’s the result
int Hplace;
int Tplace;
int Oplace;
int n;
int R;
int temp;
void setup(){
void loop(){
getValue();
      Hplace = (R/100);
      Oplace = R%10;
      Serial.println("");
   if(n==1){
    temp = Hplace;
   else if(n==2){
     temp = Tplace;
    else{
     temp = Oplace;
    switch(temp){
         case 0:
         case 1:
         case 2:
         case 3:
         case 4:
         case 5:
         case 6:
         case 7:
         case 8:
         case 9:
void getValue()
R=0;
while((R<1)||(R>999))
   //wait for data
   while (!Serial.available());
  //get the value
   R=Serial.parseInt();
  //This next bit discards any newline characters
  //or other rubbish that may still be in the buffer
   while (Serial.available())
    Serial.read();
   if((R<1)||(R>999))
      Serial.println("Now be sensible! between 1 and 999");
         case 0:
         case 1:
         case 2:
It would be much simpler to use an array to hold the names of the colours.
The IDE has CTRL-T for automatic layout. makes the code style more consequent => better readable. Check it out :wink:
   if((R<1)||(R>999))
you might use
  R = constrain(R, 1, 999); // force R between two values.
robtillaart:
OK I'll check it out. Can't promise I'll ALWAYS use it though :stuck_out_tongue:
fair enough, but I expect that if you get used to readable code you will start to miss it when not used.
FYI, I use mostly CTRL-DOWN T S U CTRL-UP (format save upload) ....
