Need to make LIBRARY/EXTRA VOID
Hello, i am making a program for a touch screen. The “setup” of the screen is always the same so i want to make it shorter. Here is my code:
#include "FT_Platform.h"
#include <SPI.h>
#define SAMAPP_DELAY_BTW_APIS (1000)
#define SAMAPP_ENABLE_DELAY() Ft_Gpu_Hal_Sleep(SAMAPP_DELAY_BTW_APIS)
#define SAMAPP_ENABLE_DELAY_VALUE(x) Ft_Gpu_Hal_Sleep(x)
char font; //0-15 minder geheugen dan int
screen();
ft_void_t Ft_App_WrDlCmd_Buffer(Ft_Gpu_Hal_Context_t *phost,ft_uint32_t cmd)
  Ft_Gpu_Hal_Wr32(phost,(RAM_DL+Ft_DlBuffer_Index),cmd);
  // Increment the command index
  Ft_DlBuffer_Index += FT_CMD_SIZE;
ft_void_t Ft_App_Flush_DL_Buffer(Ft_Gpu_Hal_Context_t *phost)
  Ft_DlBuffer_Index = 0;
// API checkt de status van de vorige DL swap en doet een nieuwe, als vorige niet gedaan is wachten en na een tijdje opnieuw proberen
ft_void_t SAMAPP_GPU_DLSwap(ft_uint8_t DL_Swap_Type)
ft_uint8_t Swap_Type = DLSWAP_FRAME,Swap_Done = DLSWAP_FRAME;
if(DL_Swap_Type == DLSWAP_LINE)
Swap_Type = DLSWAP_LINE;
// nieuwe DL swap doen
Ft_Gpu_Hal_Wr8(phost,REG_DLSWAP,Swap_Type);
// wachten tot Swap gedaan is
while(Swap_Done)
Swap_Done = Ft_Gpu_Hal_Rd8(phost,REG_DLSWAP);
if(DLSWAP_DONE != Swap_Done)
Ft_Gpu_Hal_Sleep(10); //10ms wachten
Ft_Gpu_HalInit_t halinit;
halinit.TotalChannelNum = 1;
Ft_Gpu_Hal_Init(&halinit);
host.hal_config.channel_no = 0;
host.hal_config.spi_clockrate_khz = 4000; //in KHz
       Ft_Gpu_Hal_Open(&host);
phost = &host;
       SAMAPP_BootupConfig();
       // scherm clearen
       Ft_Gpu_Hal_WrMem(phost, RAM_DL,(ft_uint8_t *)FT_DLCODE_BOOTUP,sizeof(FT_DLCODE_BOOTUP));
       Ft_Gpu_Hal_Wr8(phost, REG_DLSWAP,DLSWAP_FRAME);
ft_int32_t font,j,hoffset,voffset,stringlen;
ft_uint32_t FontTableAddress;
FT_Gpu_Fonts_t Display_fontstruct;
       // VARIABELEN
       char text[] = "GIP"; // hier tekst typen die uuitgeprint moet worden.
hoffset = ((FT_DispWidth - 100)/2);
       voffset = FT_DispHeight/2;
       stringlen = sizeof(text) - 1;
       font = 15; //0-->15
// font adres van deze locatie lezen: 0xFFFFC (vast)
FontTableAddress = Ft_Gpu_Hal_Rd32(phost, 0xFFFFC);
//font uitlezen in tabel op GPU (hardware)
Ft_Gpu_Hal_RdMem(phost,(FontTableAddress + font*FT_GPU_FONT_TABLE_SIZE),(ft_uint8_t *)&Display_fontstruct,FT_GPU_FONT_TABLE_SIZE);
       //------BEGINNEN PRINTEN SCHERM-------
        Ft_App_WrDlCmd_Buffer(phost, CLEAR(1, 1, 1)); // clear screen
        Ft_App_WrDlCmd_Buffer(phost, COLOR_RGB(255, 255, 255)); // clear screen
        //coördinaten text
        Ft_App_WrDlCmd_Buffer(phost, BEGIN(BITMAPS));
        hoffset = ((FT_DispWidth - 120)/2);
        voffset = ((FT_DispHeight - Display_fontstruct.FontHeightInPixels)/2);
        for(j=0;j<stringlen;j++) // Text tonen (letter1-->j=0; letter2-->j=1; ...)
           Ft_App_WrDlCmd_Buffer(phost, VERTEX2II(hoffset,voffset,(font+16),text[j]));
           hoffset += Display_fontstruct.FontWidth[text[j]];
        Ft_App_WrDlCmd_Buffer(phost, END());
        Ft_App_WrDlCmd_Buffer(phost, DISPLAY() );
        //DL downloaden in ram
        Ft_App_Flush_DL_Buffer(phost);
        //DL swap (& delay)
        SAMAPP_GPU_DLSwap(DLSWAP_FRAME);
               //SAMAPP_ENABLE_DELAY_VALUE(1000);
       Serial.println(text);
       Serial.print("font=");
       Serial.println(font);
void screen()
     // Waardes van scherm die gebruikt worden
     // Default WQVGA 480x272
     ft_int16_t FT_DispWidth = 480;
     ft_int16_t FT_DispHeight = 272;
     ft_int16_t FT_DispHCycle =  548;
     ft_int16_t FT_DispHOffset = 43;
     ft_int16_t FT_DispHSync0 = 0;
     ft_int16_t FT_DispHSync1 = 41;
     ft_int16_t FT_DispVCycle = 292;
     ft_int16_t FT_DispVOffset = 12;
     ft_int16_t FT_DispVSync0 = 0;
     ft_int16_t FT_DispVSync1 = 10;
     ft_uint8_t FT_DispPCLK = 5;
     ft_char8_t FT_DispSwizzle = 0;
     ft_char8_t FT_DispPCLKPol = 1;
     // dit commando wordt globaal gebruikt om de buffer te optimaliseren
     Ft_Gpu_Hal_Context_t host,*phost;
     ft_uint32_t Ft_CmdBuffer_Index;
     ft_uint32_t Ft_DlBuffer_Index;
     ft_void_t SAMAPP_BootupConfig()
      // powercycle doen (test)
      Ft_Gpu_Hal_Powercycle(phost,FT_TRUE);
      // adres 0 aanspreken om de ft800 'wakker' te maken
      Ft_Gpu_HostCommand(phost,FT_GPU_ACTIVE_M);
      Ft_Gpu_Hal_Sleep(20);
      // CLK naar externe klok zetten
      Ft_Gpu_HostCommand(phost,FT_GPU_EXTERNAL_OSC);
      // de PLL output op 48MHz zetten
      Ft_Gpu_HostCommand(phost,FT_GPU_PLL_48M);
      // core resetten
      Ft_Gpu_HostCommand(phost,FT_GPU_CORE_RESET);
      ft_uint8_t chipid;
      // chipid lezen om te weten of de ft800 klaar is
      chipid = Ft_Gpu_Hal_Rd8(phost, REG_ID);
      while(chipid != 0x7C)
         Ft_Gpu_Hal_Wr16(phost, REG_HCYCLE, FT_DispHCycle);
         Ft_Gpu_Hal_Wr16(phost, REG_HOFFSET, FT_DispHOffset);
         Ft_Gpu_Hal_Wr16(phost, REG_HSYNC0, FT_DispHSync0);
         Ft_Gpu_Hal_Wr16(phost, REG_HSYNC1, FT_DispHSync1);
         Ft_Gpu_Hal_Wr16(phost, REG_VCYCLE, FT_DispVCycle);
         Ft_Gpu_Hal_Wr16(phost, REG_VOFFSET, FT_DispVOffset);
         Ft_Gpu_Hal_Wr16(phost, REG_VSYNC0, FT_DispVSync0);
         Ft_Gpu_Hal_Wr16(phost, REG_VSYNC1, FT_DispVSync1);
         Ft_Gpu_Hal_Wr8(phost, REG_SWIZZLE, FT_DispSwizzle);
         Ft_Gpu_Hal_Wr8(phost, REG_PCLK_POL, FT_DispPCLKPol);
         Ft_Gpu_Hal_Wr8(phost, REG_PCLK,FT_DispPCLK); // na deze display zichtbaar op scherm
         Ft_Gpu_Hal_Wr16(phost, REG_HSIZE, FT_DispWidth);
         Ft_Gpu_Hal_Wr16(phost, REG_VSIZE, FT_DispHeight);
         // zet DISP_EN naar 1
         Ft_Gpu_Hal_Wr8(phost, REG_GPIO_DIR,0x83 | Ft_Gpu_Hal_Rd8(phost,REG_GPIO_DIR));
         Ft_Gpu_Hal_Wr8(phost, REG_GPIO,0x083 | Ft_Gpu_Hal_Rd8(phost,REG_GPIO));
         // Touch configuratie (de weerstandswaarde 1200) waarde hangt af van waar gebruikt wordt (resistief scherm)
         Ft_Gpu_Hal_Wr16(phost, REG_TOUCH_RZTHRESH,1200);
     const ft_uint8_t FT_DLCODE_BOOTUP[12] =
         0,255,0,0,//GPU instructie CLEAR_COLOR_RGB
         7,0,0,38, //GPU instructie CLEAR
         0,0,0,0,  //GPU instructie DISPLAY
I hope someone can help me. The place where screen(); is, is where the code of void screen should be.
Moderator edit: the usual
It will be immensely easier when you know something about C. The thing you want to make is a function, not a void. Void is a return type. If the function returned a float, you wouldn't say you needed to make a float, would you? Unless there was a parade coming up...
So, what is the problem?
PaulS:
I know but couldn't find the name. I know how C works mate i just asked some help, dont be this rude please.
PaulS:
I've solved my problem, how to delete this post?
Don't delete it, leave it here and explain the solution. Someone might benefit in the future.
