Need to modulate Bluetooth audio output based on CAN bus input
Hi guys,
Need your guidance here, would like to know if I'm going in the right direction.
  • I need to read 2 or 3 digital values from a CAN bus
  • I then need to modulate a pre-defined short base audio signal in function of the CAN bus values above (modulate the amplitude and frequency of audio signal)
  • I then need to output this final audio signal to a Bluetooth amplifier. The audio frequency will be in the bass range.
This needs to loop rather fast, i would say 10 to 100 times per second.
I've got an Arduino Uno board rev. 3
I was thinking of buying these shields:
CAN Bus shield: http://www.play-zone.ch/en/sparkfun-can-bus-shield.html
Wave Shield: http://www.play-zone.ch/en/adafruit-wave-shield-fur-arduino-kit.html
Bluetooth shield: http://www.play-zone.ch/en/adafruit-bluefruit-ez-link-shield-bt-arduino-v1-0.html
Questions:
  • Is it too much to ask to an Arduino Uno ?
  • Can i stack all these 3 shields ? Or i should rather buy breakout boards ?
thanks for your guidance,
Hugues
The Arduino is nowhere near fast enough to output audio data, by any means. Doing it via the serial port is even less likely.
PaulS:
Thanks Paul for your feed-back,
Sorry i guess i don't understand your answer. Are you saying the Arduino cannot output audio ? I guess not. But then i don't understand what else you could mean.
Isn't there a way to have the sounds in memory like we can read here:
and play them on the digital output with PWM ? Then i would not need the wave shield i mentioned in my first post ?
I would just need a short sinewave varying from around 20 HZ to maybe 100 or 200 HZ.
Sorry, i'm new to this.
