The D13 pin has the on-board LED on the UNO. It is the one nearest d13. There is nothing for you to connect.
The diagram was using a reed switch for simplicity. As you face the HED, the left-most pin is number 1, the middle pin is pin 2, and the right-most pin is pin 3.
pin 1 goes to +5V
pin 2 goes to GND
pin 3 goes to pin d12
I'll cook up another set of breadboard and schematic diagrams tonight.
You should probably test the HED individually just to see how it works.
I am attaching a breadboard and schematic for the test circuit. You should see the LED come ON when the South pole of a magnet comes near the sensor, and the LED should turn OFF when a North pole comes near the sensor. You can see how the sensor reacts to the magnet and you can also see how close your magnet needs to be to turn the sensor ON/OFF.
In the diagrams, I used a 4.8V battery pack, but you can just use jumpers from the Arduino 5V and GND.
That transistor is going to get hot. You may want to add a resistor at the emitter to ground. I don't know off hand of an actual value to use, so you may just want to use a 1K POT and adjust it.
Added: You may want to make it a darington pair, instead of a single transistor.
Almost there... We think!!
But, We can't get the motor to stop.
The test circuit worked just as explained.
Now with the circuit set up as described, when the arduino is powered up the D13 LED flashes a couple of times and then lights up. (it does this whether the magnet is aligned near the HED or not when power is turned on)
Then when the go button is pressed the motor starts but continues to run regardless of the number of times the magnet is passed over the HED.
We're sure it is connected correctly but the one component we are not sure of is the transistor. The numbers on it are 2N3904-338 it's the only one we have right now.
We tried reversing the HES and the transistor to see if polarity was a problem but no luck.
We changed the number of rotations to 3 in the code just to make the tests quicker but other than that we have made no changes to the code.
But we're at a loss as to what to try next.
Thanks
I hadn't noticed the power mod before the last post.
We are testing the setup with a 9V battery power source to the Arduino.
And all power sources connected as shown.
The transistor has not been hot at all. Could a bad transistor cause the problem we are seeing?
GrisGris:
If your code is solid, the only other real possibilties would be a shorted transistor, broken HED, or the HED is not hooked up properly or needs some other type of hook up like a pullup resistor. Also, with hall effect sensors, it will only respond to a single pole. Make sure that your pole of the magnet is correct for the sensor.
I would separate that part and test it to make sure the arduino is actually seeing the HED trigger.
Retroplayer:
We did the HED test that MaJ sent and it works so we eliminated that as a problem.
I think I'll run down to Radio Shack now and get another transistor in case that's it.
How would I isolate the HED to test it with the Arduino?
I can't really address this until tomorrow, but my first thought is that the latching HED isn't being turned OFF. Make sure that your magnet wheel has the one South pole magnet and the three North pole magnets. The HED is a latching type so when it detects the South pole it will turn ON and stay ON until it detects a North pole. Thus, if it doesn't see a North, the motor will never turn Off. Be sure that you have the magnets with the proper polarity on your sensor wheel.
Once you are sure of the magnets, using my original code, when first run it waits to see the wheel align with the South magnet. Turn the sensor wheel until the LED turns ON, then turn the sensor wheel until a North magnet is aligned with the HED and the LED should turn OFF. I suspect that the problem is with the North magnets.
ITWORKS
It was the pole sequence that we were doing wrong
and maybe the transistor,,, we replaced that too
The motor runs on the go switch then 3 passes of alternating N & S poles switches it off.
Tomorrow we'll try to put it on the car
The last test with the actual car motor looked like it may need more current because it felt pretty week compared to the little test motor. But the 9V arduino power source is getting low so maybe a fresh battery will help.
Thanks
Yes it is a 3v motor powered by 2 AAA batts. We were just touching the 3v output from the Arduino and ground to the solder joints on the board without cutting the leads so it is probably getting pulled away too.
Do you have any advice on how to extend the HED legs so it will reach out over the wheel? We were thinking of some sort of arm (paperclip) with patch wires soldered to the legs of the HED.
I would re-read some of the latest posts, use the car's native AAA batteries to power the motor. Look at the last schematic I posted. The Arduino's 3.3V is only rated @ 50mA and, if the motor draws more, you run the risk of frying your Arduino.
As far as extending the HED, I would solder some extension wires as you suggested, but I would think about a non-magnetic material for the support. A piece of plastic (like a cut down plastic knife) or a Popsicle stick.
Did you ever check how much current the motor draws? Just use the 3V AAA batteries with the motor in series with an ammeter.
