Need to program dc motors to stop at specific position
Hi, I have a code that turns on/off a motor via a distance sensor. My problem is when it turns the motor off it just turns off at a random position, and I want the motor to stop at a specific spot every time it is turned off. This way the mirror that I have attached to the shaft of the motor is back in the original level position every time the motor stops spinning.
Here's the code I have that adjusts the PWM to the motor.
#include "Ultrasonic.h"
int LED1 = 9;  // LED1 Pin
int TRIG = 2; // Trigger Pin
int ECHO = 3; // Echo Pin
int Range; // The range of the object from the HC-SR04 Ultarsonic Module
Ultrasonic ultrasonic(TRIG,ECHO); // Create and initialize the Ultrasonic object.
  pinMode(LED1, OUTPUT);
  Range = ultrasonic.Ranging(CM); // Range is calculated in Centimeters.
  // Range = ultrasonic.Ranging(INC); // Range is calculated in Inches.
  Serial.print(Range);
  Serial.println("cm");
  if (Range != 0 && Range <= 100) {
   digitalWrite(LED1, HIGH);
   delay(14);
   digitalWrite(LED1, LOW);
   delay(50);
      if (Range != 0 && Range <= 50) {
   delay(20);
   delay(50);
DC motors have no position feedback. To get the motor to stop in a particular position you will need to add a feedback sensor. This can be as simple as a switch that gets activated when the motor is in the desired position. It will be hard to hit that mark exactly. A better solution would probably be an optical encoder disk with an index mark. A pair of optical sensors can tell you how fast the motor is moving and in which direction. The index mark will allow you to target a specific stopping position.
Hmm, that's what i was afraid of.....
Thanks a lot for the suggestions, i'm afraid they may be too difficult for me to configure/code... I'll check it out though!
