I wasn't sure what section to post this in, but hopefully someone here could point me in the right direction.
The end goal of this project is to read voltage 0-5v off a PSI sensor around 100 times every second and record the data and millisecond as a text file on an SD card (shield is adafruit). The PSI sensor is connected to an air shock and we're measuring the curve of impact when dropped on the ground. Without any buttons or switches the current train of thought is to store the data to a string & write the string to a new file every 5 seconds or so. That way, when we take out the SD card to collect the data, only the last text file will be corrupted and the files containing our actual data will be have already been properly closed out. I know, it's a messy hack & we should just use a switch to close out the file...working on it.
My issue (regardless of using a switch/button) is I can only seem to get around 10 measurements a second before it starts writing non-sense to the SD card. It varies from completely empty files, to only half of the text being written, to crazy readings. I'm assuming this is a memory/bandwidth issue since when I slow it down to 10 readings/second it works fine? Any recommendations to get this up to the proper speed (100 readings/second)? Assembly? Memory tricks? Buffering? I'm currently thinking of hooking the arduino (via serial) up to my Raspberry Pi since it can store much more data before having to dump it & write to the SD card on the Pi.
#include <SPI.h>
#include <SD.h>
const int chipSelect = 10; // SD Card is hooked up to pin 10 (Ethernet Sheild uses 4)
unsigned long time;
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
//SD.begin(chipSelect);
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
Serial.println("card initialized.");
//SD.remove("/");
//Serial.println("Creating example.txt...");
//File dataFile = SD.open("datalog.txt", FILE_WRITE);
Serial.println("3");
Serial.println("2");
Serial.println("1");
// the loop routine runs over and over again forever:
String toSDcard = "";
String fileName = String(millis());
fileName += ".TXT";
File dataFile = SD.open(fileName, FILE_WRITE);
for (int i = 0; i < 30; i++) {
time = millis();
// read the input on analog pin 0:
int sensorValue = analogRead(A0);
// Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
float voltage = sensorValue * (5.0 / 1023.0);
// print out the value you read:
//toSDcard += String(time, DEC);
toSDcard += time;
toSDcard += " ";
toSDcard += String(voltage, 3); // appends float (4 decimal spaces) to string
toSDcard += '\n';
//Serial.println(toSDcard);
delay(100);
Serial.println(fileName);
dataFile.println(toSDcard);
dataFile.close();
toSDcard = "";
//Serial.println("NEW FILE!!!!");
