I did do it, took me days, then i stupidly over wrote it and now can not for the life of me remember how i done it.
So when reader 1 pops up and is read by the rfid card, it sends data, i need to be able to read this data then say if reader 0 do this or if reader 1 do that. So i need to read the byte data, but i was just messing with some other code that is reading to buffer and now i'm getting confused.
Reader 0 is a reader number and not a low or high.
#include <SPI.h>
#include <MFRC522.h>
constexpr uint8_t RST_PIN = 9; // Configurable, see typical pin layout above
constexpr uint8_t SS_1_PIN = 10; // Configurable, take a unused pin, only HIGH/LOW required, must be diffrent to SS 2
constexpr uint8_t SS_2_PIN = 8; // Configurable, take a unused pin, only HIGH/LOW required, must be diffrent to SS 1
constexpr uint8_t NR_OF_READERS = 2;
byte ssPins[] = {SS_1_PIN, SS_2_PIN};
MFRC522 mfrc522[NR_OF_READERS]; // Create MFRC522 instance.
Initialize.
Serial.begin(9600); // Initialize serial communications with the PC
while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
SPI.begin(); // Init SPI bus
for (uint8_t reader = 0; reader < NR_OF_READERS; reader++) {
mfrc522[reader].PCD_Init(ssPins[reader], RST_PIN); // Init each MFRC522 card
Serial.print(F("Reader "));
Serial.print(reader);
Serial.print(F(": "));
mfrc522[reader].PCD_DumpVersionToSerial();
Main loop.
// Look for new cards
if (mfrc522[reader].PICC_IsNewCardPresent() && mfrc522[reader].PICC_ReadCardSerial()) {
// Halt PICC
mfrc522[reader].PICC_HaltA();
// Stop encryption on PCD
mfrc522[reader].PCD_StopCrypto1();
} //if (mfrc522[reader].PICC_IsNewC
} //for(uint8_t reader
