Hey,
this is my very first post in this forum, I hope I don’t mess this up.
Short summary of my project and what already works:
- I want a user to provide an input (number) to the serial monitor.
- For this I was basically following: Robin2’s amazing post for retrieving a single digit (i.e., Example 4).
- I also attached some IR breakbeam sensor.
- I can count the number of times the sensor is broken up unto the provided user input number
The problem is; I need to do this operation twice, if I set the line ending to Newline. If I set it to No Line Ending then it works. However, No Line Ending works only for the first digit that is provided. Subsequent inputs are not recognized.
What is the issue here for Newline?
Thank you!
// IR PART
// IR Breakbeam Sensor Definitions
#define SENSORPIN 4
// IR breakbeam sensor state variables
int currentSensorState = 0, lastSensorState = 0; // either LOW or HIGH (i.e., 0 or 1. NB: LOW means beam is broken, HIGH means unbroken)
// IR counter
int counter = 0;
bool isCounting = false;
// SERIAL INPUT PART
char receivedChars[32];
bool newData = false;
int dataNumber = 0;
// initialize the sensor pin as an input:
pinMode(SENSORPIN, INPUT);
digitalWrite(SENSORPIN, HIGH);
Serial.println("Arduino Ready");
void loop(){
// check & receive new user input, newline should be used as EOL (LF)
if (Serial.available() > 0) {
// get serial input
recvWithEndMarker();
// cast input to int
dataNumber = atoi(receivedChars);
// enable counting mode
isCounting = true;
newData = false;
while (isCounting) {
// Sensor Algorithm
// read the current sensor state
currentSensorState = digitalRead(SENSORPIN);
// if there is a diff in currentSensorState and lastSensorState
if (currentSensorState == HIGH && lastSensorState == LOW) {
Serial.println("Unbroken");
if (currentSensorState == LOW && lastSensorState == HIGH) {
Serial.println("Broken");
// if beam is broken we can assume that an object is blocking it, so incrementing the counter
counter += 1;
Serial.println(counter);
// synchronize states (this should be at the end)
lastSensorState = currentSensorState;
// reset isCounting when reached the counter
if (dataNumber == counter) {
Serial.println("Done Counting");
isCounting = false;
// reset counter to 0 to prepare for next runs
counter = 0;
void recvWithEndMarker() {
static byte ndx = 0;
char endMarker = '\n';
char rc;
rc = Serial.read();
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= 32) {
ndx = 32 - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
