Need to store the keypad inputs as one input
Iam triying to make online attendance using Arduino.I need to use a number like 150 from the input using the keypad.
<if (input == '11' ) {
Serial.print("!!--");
Serial.println(key);
NAME = "Dog";
ID = "11";
makeIFTTTRequest();
Serial.print("Attendace Marked for "); Serial.println(NAME);
input = "";
As in above i need to take many digits as one single number like 1130.
I need the help with the code
See Keypad data entry. A beginners guide
  if (key >= '0' && key <= '9')
    Serial.print(key);
    input *= 10;
    input += key - '0';
  if (key == '#') // 'enter'
  switch (input)
  case 11:
    NAME = "Dog";
    ID = "11";
    makeIFTTTRequest();
    Serial.print("!!--Attendace Marked for ");
    input = 0;
I came with an error
Compilation error: no match for 'operator*=' (operand types are 'String' and 'int')
This is my whole code can you pls edit the errors
#include <WiFi.h>
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
char keys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[ROWS] = {13,12,14,27}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {26,25,33,32}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
const char* NAME;
const char* ID;
String Event_Name = "Attendance";
String Key = "nlGjtBEifiySWwQmTgZAipFdSmCgQLXOa4cMcAnin05";
// Replace with your unique IFTTT URL resource
String resource = "/trigger/" + Event_Name + "/with/key/" + Key;
// Maker Webhooks IFTTT
const char* server = "maker.ifttt.com";
// Replace with your SSID and Password
const char* ssid     = "Dineth";
const char* password = "Dineth2008";
String input;
  input.reserve(1000);
  while (!Serial);  // For Yun/Leo/Micro/Zero/...
  delay(100);
  // set the data rate for the sensor serial port
  Serial.print("Connecting to: ");
  Serial.print(ssid);
  WiFi.begin(ssid, password);
  int timeout = 10 * 4; // 10 seconds
  while (WiFi.status() != WL_CONNECTED  && (timeout-- > 0)) {
    delay(250);
    Serial.print(".");
  Serial.println("");
  if (WiFi.status() != WL_CONNECTED) {
    Serial.println("Failed to connect, going back to sleep");
  Serial.print("WiFi connected in: ");
  Serial.print(millis());
  Serial.print(", IP address: ");
  char key = keypad.getKey();
if (key){
    Serial.print(key);
    input *= 10;
    input += key - '0';
  switch (input)
  case 11:
    NAME = "Dog";
    ID = "11";
    makeIFTTTRequest();
    input = 0;
void makeIFTTTRequest() {
  Serial.print("Connecting to ");
  Serial.print(server);
  WiFiClient client;
  int retries = 5;
  while (!!!client.connect(server, 80) && (retries-- > 0)) {
    Serial.print(".");
  if (!!!client.connected()) {
    Serial.println("Failed to connect...");
  Serial.print("Request resource: ");
  Serial.println(resource);
  // Temperature in Celsius
  String jsonObject = String("{\"value1\":\"") + NAME + "\",\"value2\":\"" + ID+ "\"}";
  client.println(String("POST ") + resource + " HTTP/1.1");
  client.println(String("Host: ") + server);
  client.println("Connection: close\r\nContent-Type: application/json");
  client.print("Content-Length: ");
  client.println(jsonObject.length());
  client.println();
  client.println(jsonObject);
  int timeout = 5 * 10; // 5 seconds
  while (!!!client.available() && (timeout-- > 0)) {
    delay(100);
  if (!!!client.available()) {
    Serial.println("No response...");
  while (client.available()) {
    Serial.write(client.read());
  Serial.println("\nclosing connection");
  client.stop();
#include <WiFi.h>
#include <Keypad.h>
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
byte rowPins[ROWS] = {13, 12, 14, 27}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {26, 25, 33, 32}; //connect to the column pinouts of the keypad
const char* NAME;
const char* ID;
int input;
  // input.reserve(1000);
  delay(100);
  Serial.print(ssid);
    delay(250);
    Serial.print(".");
  Serial.println("");
  if (key)
      Serial.print(key);
      input *= 10;
      input += key - '0';
      switch (input)
        case 11:
          NAME = "Dog";
          ID = "11";
          makeIFTTTRequest();
          input = 0;
  WiFiClient client;
  int retries = 5;
    Serial.print(".");
  String jsonObject = String("{\"value1\":\"") + NAME + "\",\"value2\":\"" + ID + "\"}";
  client.println();
    delay(100);
  client.stop();
thanks it worked.But how to add backspace using the * key
MY experience was that it is easier to add a "cancel" key and just start over.
Did you mean if I pressed the * key, set input to 0?
Yes.
I did it thanks
Any way to enter the data quickly?Because I need to enter 100++ data.
case 11:
          SendData();
          NAME = "Parrot";
          ID = "11";
         case 12:
          SendData();
          NAME = "bla";
          ID = "12";
If you mean that you need to have 100 or so cases then start by copy/pasting a single case as many times as you need to then edit what you have pasted
As each case does basically the same thing you could achieve the same result by putting the NAMEs in an array and using the case value to access the NAME entry. That way there would be no need for switch/case at all
Either way, you will need to be careful not to run out of memory. Which Arduino are you using ?
Im using esp32
Is your main problem that you have over 100 NAME values ? If so, don't use over 100 cases in switch. Instead build an array of the NAMEs then use the value of the case variable to access the associated NAME and to derive the value of the ID. Does the ID really need to be a string or could it just use the case variable value ? What is us used for ?
The fact that you call SendDate() before setting any variables also looks wrong but without seeing a complete sketch it is impossible to say
Where is the data now? Are the ID's already assigned or do you get to make those up?
This is my code. What are the edits I should make to make it easy?
#include <WiFi.h>
#include <Keypad.h>
  { '1', '2', '3', 'A' },
  { '4', '5', '6', 'B' },
  { '7', '8', '9', 'C' },
  { '*', '0', '#', 'D' }
byte rowPins[ROWS] = { 13, 12, 14, 27 };  //connect to the row pinouts of the keypad
byte colPins[COLS] = { 26, 25, 33, 32 };  //connect to the column pinouts of the keypad
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
const char* NAME;
const char* ID;
int input;
  Serial.print(ssid);
    delay(250);
    Serial.print(".");
  Serial.println("");
  if (key) {
    if (key >= '0' && key <= '9') {
      Serial.print(key);
      input *= 10;
      input += key - '0';
      switch (input) {
        case 11:
          SendData();
          NAME = "Parrot";
          ID = "11";
        case 12:
          SendData();
          NAME = "bla";
          ID = "12";
        default:
          input = 0;
          Serial.println("Wrong Input");
    if (key == '*') {
      input = 0;
      Serial.println("Input Cleared");
// Make an HTTP request to the IFTTT web service
  WiFiClient client;
  int retries = 5;
    Serial.print(".");
  client.println();
    delay(100);
  client.stop();
void SendData() {
  makeIFTTTRequest();
  input = 0;
Put the names and ID's into either two parallel lists or one list of structures.
struct {
  const char * name;
  const int id;
} Users = {
{"Parrot", 11},
{"bla", 12},
size_t UserCount = sizeof Users / sizeof Users[0];
Then you can check the entered ID against the list:
      for (size_t i=0; i < UserCount; i++)
        if (input == Users[i].id)
          NAME = Users[i].name;
          ID = Users[i].id;
          SendData();
          input = 0;  // Prepare for next input
          return;
      // User ID not found!
      input = 0;
So I only need to add names and IDs to this array. Then the code will run as usual.
Is that all?
I think so. Put in a few names and IDs and get that working. Then you can add the rest.
Note: I should have written:
} Users[] = {
{"Parrot", 11},
{"bla", 12},
