Need to use a ESPNOW for sending the pir sensor data from one NodeMCU to another NodeMCU
Hi, I'm kinda new to working with sensors and the ESP8266 board. Kindly help me out with interfacing the PIR sensor with NodeMCU and getting the data from the sensor.
Thanks but using ESP-NOW to send messages I also know well. I have to send the PIR sensor data using this protocol. I'm facing an issue getting PIR sensor data.
The Random Nerd has a tutorial for connecting a PIR to an ESP, too.
I'm struggling with the process of sending the sensor data using ESP-NOW not connecting it to ESP8266. I'm able to connect, but getting the sensor data and sending it to another ESP8266 using the ESP-NOW protocol is where I need help.
have a look at esp-now-two-way-communication-esp8266-nodemcu
here is an example using a structure to hold sensor data to be transmitted over ESP-NOW
transmitter
// ESP-now - send sensor data in a structure
  Rui Santos
  Complete project details at https://RandomNerdTutorials.com/esp-now-esp32-arduino-ide/
  Permission is hereby granted, free of charge, to any person obtaining a copy
  of this software and associated documentation files.
  The above copyright notice and this permission notice shall be included in all
  copies or substantial portions of the Software.
#include <esp_now.h>
#include <WiFi.h>
// REPLACE WITH YOUR RECEIVER MAC Address
uint8_t broadcastAddress[] = {0x84, 0xCC, 0xA8, 0x7A, 0x56, 0x6C};
// Structure example to send data
// Must match the receiver structure
typedef struct struct_message {
  char a[32];
  int b;
  float c;
  bool d;
} struct_message;
// Create a struct_message called myData
struct_message myData;
esp_now_peer_info_t peerInfo;
// callback when data is sent
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status) {
  Serial.print("\r\nLast Packet Send Status:\t");
  Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
  // Init Serial Monitor
  // Set device as a Wi-Fi Station
  WiFi.mode(WIFI_STA);
  // Init ESP-NOW
  if (esp_now_init() != ESP_OK) {
    Serial.println("Error initializing ESP-NOW");
    return;
  // Once ESPNow is successfully Init, we will register for Send CB to
  // get the status of Trasnmitted packet
  esp_now_register_send_cb(OnDataSent);
  // Register peer
  memcpy(peerInfo.peer_addr, broadcastAddress, 6);
  peerInfo.channel = 0;
  peerInfo.encrypt = false;
  // Add peer
  if (esp_now_add_peer(&peerInfo) != ESP_OK){
    Serial.println("Failed to add peer");
    return;
  // Set values to send
  strcpy(myData.a, "THIS IS A CHAR");
  myData.b = random(1,20);
  myData.c = 1.2;
  myData.d = false;
  // Send message via ESP-NOW
  esp_err_t result = esp_now_send(broadcastAddress, (uint8_t *) &myData, sizeof(myData));
  if (result == ESP_OK) {
    Serial.println("Sent with success");
  else {
    Serial.println("Error sending the data");
  delay(2000);
receiver
// ESP-now - receive sensor data in a structure
  Rui Santos
#include <WiFi.h>
// Structure example to receive data
// Must match the sender structure
    char a[32];
    int b;
    float c;
    bool d;
} struct_message;
// callback function that will be executed when data is received
void OnDataRecv(const uint8_t * mac, const uint8_t *incomingData, int len) {
  memcpy(&myData, incomingData, sizeof(myData));
  Serial.print("Bytes received: ");
  Serial.println(len);
  Serial.print("Char: ");
  Serial.println(myData.a);
  Serial.print("Int: ");
  Serial.println(myData.b);
  Serial.print("Float: ");
  Serial.println(myData.c);
  Serial.print("Bool: ");
  Serial.println(myData.d);
  // Initialize Serial Monitor
  Serial.print("ESP32 Board MAC Address:  ");
  Serial.println(WiFi.macAddress());
  // Init ESP-NOW
    return;
  // Once ESPNow is successfully Init, we will register for recv CB to
  // get recv packer info
  esp_now_register_recv_cb(OnDataRecv);
