In building some of the OttoDIY projects, I'm looking for a small, 5A battery power system that needs to be about 60mmx60mm. I am looking to use a small 2S lipo with high discharge (for up to 6 MG90s servos) and I can easily find an XL4015 step down @5A converter. But I want to protect the Lipo from discharge below, say 7v. (not sure I need to measure each cell). Is there a simple, small undervoltage protection module that exists? I don't need a charger.. I can remove and use my balanced LiPo charger. I'm not sure if a BMS module is designed just for under-discharge voltage.. seems it is more for being integrated into a charger.
An alternative solution would be to have the converter shut down if under a pre-set input voltage.. (using a POT to set input Vin(min) to say 7v.._) but that might be a unicorn dream.
there are some nice solutions for 2x 18650 batteries.. but the module is too large to be used in the OttoDIY projects.
Thanks for any nudges in the right direction.
