Need very simple help with push button
So i'm new to Arduino and just start learning.
I can do this easily
void setup() { pinMode(2, INPUT); pinMode(3, OUTPUT); pinMode(4, OUTPUT); }
void loop() { // read the switch input: if (digitalRead(2) == HIGH) { // if the switch is closed: digitalWrite(3, HIGH); digitalWrite(4, LOW); } else { // if the switch is open: digitalWrite(3, LOW); digitalWrite(4, HIGH); } }
but when i try to put 2 push pin with this code
void setup() { pinMode(2, INPUT); pinMode(3, OUTPUT); pinMode(4, OUTPUT); pinMode(5, INPUT); pinMode(6, OUTPUT); pinMode(7, OUTPUT); }
if (digitalRead(5) == HIGH) {
digitalWrite(6, HIGH); digitalWrite(7, LOW); }
else { // if the switch is open: digitalWrite(3, LOW); digitalWrite(4, HIGH); digitalWrite(6, LOW); digitalWrite(7, HIGH); } }
it doesnt work well
here is a video: http://youtu.be/qeMQI2vr410
The code is the same for INPUT 2 and 5 but they act different?
Here's how I connected the Arduino and the breadboard: The resistors for the LEDs are 470 ohms The resistors for the push buttons are 10K
Thank you for your help!
Why only the input 5 have a 'else'?
luisilva: Why only the input 5 have a 'else'?
Thank you so much! I knew there was something wrong with the code but since i didnt write in C a long time ago i could not find my mistake!
Here's the code with input 2 having a 'else' if it can help someone:
else { // if the switch is open: digitalWrite(6, LOW); digitalWrite(7, HIGH); } }
If you look at your program one of the outputs always equals the correspond switch input and the other is the inverse of it
Try
  digitalWrite(3, digitalRead(2));
  digitalWrite(4, !digitalRead(2));
  digitalWrite(6, digitalRead(5));
  digitalWrite(7, !digitalRead(5));
This compiles and shows what you can do just with arrays and loops.
Would you rather chisel code in stone or carve it with power tools?
const byte numInputs = 2;
const byte numOutputs = 4;
const byte inputPins[numInputs] = {
  2, 5 };
const byte outputPins[numOutputs] = {
  3, 4, 6, 7 };
  for ( byte i = 0; i < numInputs; i++ )
    pinMode( i, INPUT );
  for ( byte i = 0; i < numOutputs; i++ )
    pinMode( i, OUTPUT );
  static byte i = 0;
  static byte temp;
  if ( digitalRead( inputPins[ i ]))
    digitalWrite( i+1, HIGH);
    digitalWrite( i+2, LOW);
    digitalWrite( i+1, LOW );
    digitalWrite( i+2, HIGH );
  if ( ++i >= numInputs ) // increments i then compares to numInputs
    i = 0;
ps kaboche, if the inputs are buttons and the circuit is breadboard then consider changing the input mode to INPUT_PULLUP, wire pin to switch to GND. The chip has a built-in pullup resistor of 20K to 50k, in that mode the pin is ground-safe. My Q&D button is a jumper grounded on the bare metal USB box.
