Need wire size recomendation
What wire size should I use for my project.
I am going to mount and wire a number of components on perforated double sided fiber board.
I am wondering what wire size I should use, Stranded or solid.?
Thanks
It depends on the current required and flex.
For most low current (<250ma) applications, I use #24 AWG 7 stranded wire.
I want to solder to the small square pads and route the wires to other pads.
If you are doing a point to point wiring circuit board, all low current, #30 solid wire wrap wire will do.
See:
#30 solid is hard to find it seems.
Google wire wrap wire.
http://www.king-cart.com/phoenixent/product_name=HWS16030/category=WIRE+%26+CABLE+-+BULK/exact_match=exact
Jameco
https://www.jameco.com/shop/StoreCatalogDrillDownView?langId=-1&storeId=10001&catalogId=10001&freeText=wire-wrap&search_type=jamecoall
