need your suggestion..
i'm having a hard time figuring out how to make my gsm accepts only 3 mobile numbers for it to be commanded..
my previous work was the gsm to accept only 1 mobile number.. here's my code..
#include <FrequencyTimer2.h>
#include <SD.h>
#include<stdlib.h>
#define SD_CS 4
#define RELAY 5
#define GSM_POWER 6
#define GSM Serial
#define LED 14
#define analyzer Serial1
static String cpNum = "09XX-XXXX-XXX";
unsigned long uptime = 0;
boolean stat;
String aData;
String resp;
char msgLog[100];
char buffer[13];
//Called once on start of Arduino
  pinMode(LED, OUTPUT);
  SD.begin(SD_CS);
  analyzer.begin(9600);
  pinMode(RELAY, OUTPUT);
  FrequencyTimer2::setPeriod(16000);
  GSM.begin(9600);
  pinMode(GSM_POWER, OUTPUT);
  digitalWrite(GSM_POWER, LOW);
  delay(1500);
  digitalWrite(GSM_POWER, HIGH);
  delay(2000);
  while (readCmd() != "Call Ready");
  GSM.println("ATE0");
  while (readCmd() != "OK");
  digitalWrite(LED, HIGH);
void powerOn() {
  digitalWrite(RELAY, HIGH);
  strcpy(msgLog, "POWER ON");
  writeToFile();
  FrequencyTimer2::setOnOverflow(incUptime);
void getData() {
  int commaLoc[7];//response from
  commaLoc[0] = aData.indexOf(',');
  for (byte i = 1; i < 7; i++) {
    commaLoc[i] = aData.indexOf(',', commaLoc[i - 1] + 1);
void powerOff() {
  int i = 0;
  digitalWrite(RELAY, LOW);
  strcpy(msgLog, "POWER OFF ");
  while (msgLog[i] != '\0') {i++;}
  strcat(msgLog, buffer);
  stat = 0;
  FrequencyTimer2::setOnOverflow(0);
  writeToFile();
  while(analyzer.available()) {
    analyzer.read();
void incUptime() {
  static byte cnt = 0;
  if (++cnt == 125) {
    cnt = 0;
    ++uptime;
String getUptime() {
  unsigned long hr = uptime / 3600;
String leftPad(unsigned long num) {
  String str = String(num);
  if (num < 10) {
    str = "0" + str;
  return str;
boolean sendSMS(String num, String msg) {
  GSM.print("AT+CMGS=\"");//AT command for sending message
  GSM.print(num);
  GSM.println("\"");
  while(GSM.read() != '>');//'>'
  GSM.print(msg);
  GSM.write(26);
  while(1) {
    String inpt = readCmd();
    if (inpt.startsWith("+CMGS")) {
      return 1;
    else if (inpt.startsWith("+CMS") || inpt.startsWith("ERROR")) {
      return 0;
void writeToFile() {
  File dataFile = SD.open("datalog.txt", FILE_WRITE);
  if (dataFile) {
    dataFile.println(msgLog);
    dataFile.close();
String readCmd() {
  String cmd = "";
  char tmp;
  while (1) {
    if ((tmp = GSM.read ()) != -1) {
      if (tmp == 10) {
        if ((cmd.length () > 1 || !cmd.startsWith ("+CMTI")) &&
cmd.endsWith ("\r")) {
          return cmd.substring (0, cmd.length () - 1);
          cmd = "";
        cmd += tmp;
String readSMS () {
  String msg = "", inpt = "";
  boolean msgRead = false;
  byte comma[3];
  byte i;
  GSM.println("AT+CMGL=\"REC UNREAD\",1");
  while ((inpt = readCmd()) != "OK") {
    if (!msgRead && inpt.startsWith("+CMGL")) {
      msgRead = true;
      for (i = 1; i < 3; i++) {
        comma[i] = inpt.indexOf(',', comma[i - 1] + 1);
      msg = inpt.substring(comma[1] + 2, comma[2] - 1);
      if (msg.startsWith("+63")) {
        msg = "0" + msg.substring(3);
      msg += ',';
      char temp;
      while ((temp = GSM.read()) != '\r') {
        if (temp != -1) {
          msg += temp;
  if (msgRead) {
    GSM.print("AT+CMGD=");
    GSM.println (",0");
  return msg;
void checkMessages() {
  String msg = readSMS();
  if (msg.startsWith (cpNum)) {
    respond(msg.substring (msg.indexOf (',') + 1));
void respond (String cmd) {
  if (cmd == "STATUS") {
    if (stat) {
      resp = "Power is ON.\n";
      resp = resp + "Uptime: " + getUptime();
      resp = "Power is OFF.";
  } else if (cmd == "POWER ON") {
    if (stat) {
      resp = "Power is already ON.";
      powerOn();
      resp = "Power ON successful";
  } else if (cmd == "POWER OFF") {
    if (!stat) {
      resp = "Power is already OFF.";
      powerOff();
      resp = "Power OFF successful. " + getUptime();
    resp = "Invalid Command.";
  sendSMS(cpNum, resp);
Is there any special command for this matter? thank you in advance!..
How to use this forum
#7 particularly.
Arrch:
#7 particularly.
done bro..
Start by taking your single String:
and convert it to an array containing all 3 of the numbers Then when you are comparing the number with the number of the sent message:
use a for loop, and loop through all of the 3 elements in the array
Arrch:
this may sound stupid but just to be safe.. is this code also acceptable without affecting the other codes or future codes to be encoded? thank you!
static String cpNum1 = "09YY-YYYY-YYY";
then
   else if (msg.startsWith (cpNum1)){
    resp = "Invalid Number!.";
