Hello
I would like to use an NRF24L01 module, an arduino Nano, and a 2.4gh transmitter to controll 4x 2.7v high speed motors. This is for a quadcopter project.
How do I do this?
Do I need to use a motor driver, or is it ok to connect the motors directly to the nano?
This is a complex project, and not really suited to someone without detailed experience - sorry but asking if you can power from the Arduino suggests that.
The motors take 10+
Amps and need dedicated seperate speed controllers for the brushless motors, so you can turn, bank and go up/down. The flight control boards you can buy are significantly more powerful than a Nano.
If you do want to look further have a google for projects.
Thank you for your reply.
I was just thinking of using a Nano to reduce weight.
Is there a motor driver which will allow me to control four motors independently?
Thank you.
Natha:
Do you need your quadcopter to fly upside-down? If not, you would not need a bi-directional motor controller and a simple MOSFET would give you speed control over one motor. Use four of them for four motors.
Natha:
I was just wondering if the ardu-con (arduino controller) iphone app would work to control it.
From what I have read, you need a BLE (Bluetooth Low Energy) interface to connect to the iPhone. A regular Bluetooth module won't work. I imagine the Ardu-con documentation discusses the hardware requirements.
Natha:
You will need to use an nRF24L01+ for the transmitter also - I guess one of the high-power modules with the external antenna would be best. However I have had a pair of low-power modules (with the PCB antenna) working at 110m outdoors with clear line of sight.
