been trying to make a watch with 7 segement displays but i keep getting this when uploading my code Arduino: 1.8.20 Hourly Build 2021/12/20 07:33 (Windows 10), Board: "Arduino Uno"
C:\arduino-nightly\arduino-builder -dump-prefs -logger=machine -hardware C:\arduino-nightly\hardware -tools C:\arduino-nightly\tools-builder -tools C:\arduino-nightly\hardware\tools\avr -built-in-libraries C:\arduino-nightly\libraries -libraries \dsbnacfss2\sccstudents$\mondora\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0000_0000 -ide-version=10820 -build-path C:\Users\MONDORA\AppData\Local\Temp\arduino_build_970646 -warnings=none -build-cache C:\Users\MONDORA\AppData\Local\Temp\arduino_cache_192023 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\arduino-nightly\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\arduino-nightly\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\arduino-nightly\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\arduino-nightly\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\arduino-nightly\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\arduino-nightly\hardware\tools\avr -verbose C:\Users\MONDORA\Downloads\sketch_jun14a\sketch_jun14c\sketch_jun14c.ino
C:\arduino-nightly\arduino-builder -compile -logger=machine -hardware C:\arduino-nightly\hardware -tools C:\arduino-nightly\tools-builder -tools C:\arduino-nightly\hardware\tools\avr -built-in-libraries C:\arduino-nightly\libraries -libraries \dsbnacfss2\sccstudents$\mondora\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0000_0000 -ide-version=10820 -build-path C:\Users\MONDORA\AppData\Local\Temp\arduino_build_970646 -warnings=none -build-cache C:\Users\MONDORA\AppData\Local\Temp\arduino_cache_192023 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\arduino-nightly\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\arduino-nightly\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\arduino-nightly\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\arduino-nightly\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\arduino-nightly\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\arduino-nightly\hardware\tools\avr -verbose C:\Users\MONDORA\Downloads\sketch_jun14a\sketch_jun14c\sketch_jun14c.ino
Using board 'uno' from platform in folder: C:\arduino-nightly\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\arduino-nightly\hardware\arduino\avr
Detecting libraries used...
"C:\arduino-nightly\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10820 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\arduino-nightly\hardware\arduino\avr\cores\arduino" "-IC:\arduino-nightly\hardware\arduino\avr\variants\standard" "C:\Users\MONDORA\AppData\Local\Temp\arduino_build_970646\sketch\sketch_jun14c.ino.cpp" -o nul
Generating function prototypes...
"C:\arduino-nightly\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10820 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\arduino-nightly\hardware\arduino\avr\cores\arduino" "-IC:\arduino-nightly\hardware\arduino\avr\variants\standard" "C:\Users\MONDORA\AppData\Local\Temp\arduino_build_970646\sketch\sketch_jun14c.ino.cpp" -o "C:\Users\MONDORA\AppData\Local\Temp\arduino_build_970646\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\arduino-nightly\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\MONDORA\AppData\Local\Temp\arduino_build_970646\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\arduino-nightly\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10820 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\arduino-nightly\hardware\arduino\avr\cores\arduino" "-IC:\arduino-nightly\hardware\arduino\avr\variants\standard" "C:\Users\MONDORA\AppData\Local\Temp\arduino_build_970646\sketch\sketch_jun14c.ino.cpp" -o "C:\Users\MONDORA\AppData\Local\Temp\arduino_build_970646\sketch\sketch_jun14c.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\MONDORA\AppData\Local\Temp\arduino_cache_192023\core\core_arduino_avr_uno_3936bfcb62be9c7e518374d8cba2eadd.a
Linking everything together...
"C:\arduino-nightly\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\MONDORA\AppData\Local\Temp\arduino_build_970646/sketch_jun14c.ino.elf" "C:\Users\MONDORA\AppData\Local\Temp\arduino_build_970646\sketch\sketch_jun14c.ino.cpp.o" "C:\Users\MONDORA\AppData\Local\Temp\arduino_build_970646/..\arduino_cache_192023\core\core_arduino_avr_uno_3936bfcb62be9c7e518374d8cba2eadd.a" "-LC:\Users\MONDORA\AppData\Local\Temp\arduino_build_970646" -lm
"C:\arduino-nightly\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\MONDORA\AppData\Local\Temp\arduino_build_970646/sketch_jun14c.ino.elf" "C:\Users\MONDORA\AppData\Local\Temp\arduino_build_970646/sketch_jun14c.ino.eep"
"C:\arduino-nightly\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\MONDORA\AppData\Local\Temp\arduino_build_970646/sketch_jun14c.ino.elf" "C:\Users\MONDORA\AppData\Local\Temp\arduino_build_970646/sketch_jun14c.ino.hex"
"C:\arduino-nightly\hardware\tools\avr/bin/avr-size" -A "C:\Users\MONDORA\AppData\Local\Temp\arduino_build_970646/sketch_jun14c.ino.elf"
Sketch uses 7038 bytes (21%) of program storage space. Maximum is 32256 bytes.
Global variables use 249 bytes (12%) of dynamic memory, leaving 1799 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xca
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xca
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
Blockquote
