Neeed help with my project, fan and digital tempsensor not working properly
Hi
I have started a little project for my room where im having a fan that will start spinning at a certain speed and at a certain temperatur. At first a use this (1) method but my lm35 wasnt showing that accurate temp (but the fan spinned faster if the temps was higher) so i bought a DS18B20. I found that it was way more precisely and it showed the real temperatur but the thing is i didnt get a working code that could controlled a fan so it started slow and when the temps got higher the fans spinns faster. I was only able got it so it turned on 100% power. I used a dallas temperatur example and then change it a bit. (2)
(1) http://www.electroschematics.com/9540/arduino-fan-speed-controlled-temperature/
(2) http://www.instructables.com/id/Temperature-with-DS18B20/
/BarackoArne :smiley:
#include <OneWire.h>
// OneWire DS18S20, DS18B20, DS1822 Temperature Example
// http://www.pjrc.com/teensy/td_libs_OneWire.html
// The DallasTemperature library can do all this work for you!
// http://milesburton.com/Dallas_Temperature_Control_Library
OneWire  ds(2);  // on pin 10 (a 4.7K resistor is necessary)
float temp;
int tempMin = 24;
int tempMax = 29;
int fan = 4;
int fanSpeed = 0;
void setup(void) {
 pinMode(fan, OUTPUT);
 if(temp < tempMin) { // if temp is lower than minimum temp
fanSpeed = 0; // fan is not spinning
digitalWrite(fan, LOW);
if((temp >= tempMin) && (temp <= tempMax)) //if temperature is higher than the minimum range
fanSpeed = map(temp, tempMin, tempMax, 100, 255); // the actual speed of fan
analogWrite(fan, fanSpeed); // spin the fan at the fanSpeed speed
 byte i;
 byte present = 0;
 byte type_s;
 byte data[12];
 byte addr[8];
 float celsius, fahrenheit;
 if ( !ds.search(addr)) {
 for( i = 0; i < 8; i++) {
 if (OneWire::crc8(addr, 7) != addr[7]) {
     Serial.println("CRC is not valid!");
     return;
 // the first ROM byte indicates which chip
 switch (addr[0]) {
 ds.reset();
 ds.select(addr);
 ds.write(0x44, 1);        // start conversion, with parasite power on at the end
 delay(1000);     // maybe 750ms is enough, maybe not
 // we might do a ds.depower() here, but the reset will take care of it.
 present = ds.reset();
 ds.select(addr);
 ds.write(0xBE);         // Read Scratchpad
 for ( i = 0; i < 9; i++) {           // we need 9 bytes
   data = ds.read();
 // Convert the data to actual temperature
 // because the result is a 16 bit signed integer, it should
 // be stored to an "int16_t" type, which is always 16 bits
 // even when compiled on a 32 bit processor.
 int16_t raw = (data[1] << 8) | data[0];
 if (type_s) {
   raw = raw << 3; // 9 bit resolution default
   if (data[7] == 0x10) {
     // "count remain" gives full 12 bit resolution
     raw = (raw & 0xFFF0) + 12 - data[6];
   byte cfg = (data[4] & 0x60);
   // at lower res, the low bits are undefined, so let's zero them
   if (cfg == 0x00) raw = raw & ~7;  // 9 bit resolution, 93.75 ms
   else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
   else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
   //// default is 12 bit resolution, 750 ms conversion time
 temp = (float)raw / 16.0;
 fahrenheit = celsius * 1.8 + 32.0;
 Serial.print(temp);
 Serial.print(" C ");
Can you please post a copy of your sketch, using code tags?
They are made with the </> icon in the reply Menu.
See section 7 http://forum.arduino.cc/index.php/topic,148850.0.html
I see you are using pin4 as fan control with analogWrite, pin4 is not a PWM pin. 3,5,6,9,10 and 11 on the UNO are.
If you look at the UNO PCB you will see ~ signs next to pins that support PWM.
The output is not an analog voltage level, it is a PWM signal with variable duty cycle.
Tom… :slight_smile:
Im using a arduino nano and im using a none pwm fan.
Do i have to connect the fan to a output with a ~ symbol on it?
I think that i put the fan output on a none pwm output beacuse on arduinos product page the arduino nano shows that the pwm output is 3, 5, 6, 9, 10, and 11. i will try to change output port.
What sort of fan are you trying to control?
Tom.. :slight_smile:
Please do not cross-post. This wastes time and resources as people attempt to answer your question on multiple threads.
Your other thread deleted.
  • Moderator
TomGeorge:
there is a schematic on this website http://www.electroschematics.com/wp-content/uploads/2014/01/arduino-temperature-fan-speed-control-550x494.png
i used this schematic but i used a DS18B20 temp sensor instead of a lm35. Im using a 3 pin computer fan. i think that the problem is that im using a output that is not pwm beacuse im using output 2 and its not an pwm output so i will try to change it later.
If you are using a computer fan it may not control very well with PWM or variable DC.
If it is a Brushless DC Motor, it has its own controller built in.
The third wire is usually a tacho OUTPUT, pulsing once per fan revolution.
Tom.... :slight_smile:
At first I tried using a lm35 and it worked pretty good but the readings from it wasn't accurate. I got the (with the lm35) fan to spinning at a sertan temperature but when I'm using the DS18B20 I won't get it to work properly( the fan turns on at max speed when then temp is over 27 or something)....
