I recently purchased a couple of Neewer L298N motor controllers.
Specifically: Amazon.com
Is there any pinout picture or chart for this model? I understand that there is a 5v in, ground, and then 12v+ in at the front there.
Which is which? I'm assuming ground is the middle, but which is 5v in and 12v+ in? From the picture there appear to be no labels. Any help is appreciated.
Additional information:
I've noticed that some models have VCC on the left and logic power on the right while others have VCC on the right and logic power on the left.
We can do this the easy way , or the hard way.
Apparently , recently purchased does not equate to recently obtained, so you don't know that the silk screen labels you are asking
about are hidden by the 3 pin connector, which you'll find out when you receive them. If you want to satisfy your curiosity so you can sleep at night you can pull up the datasheet for the L298 and look at the pin number for the logic Vcc and you can check continuity with a meter when you get it, but by then you will have seen the labels on the other side of the connector. Conversely, you can identify ground by doing a continuity check to the ground pins of the chip. So there's not much of a mystery there.
(see attached) http://www.amazon.com/Retailstore-Arrival-Stepper-Controller-Arduino/dp/B009LTSTJA/ref=pd_sxp_grid_i_2_2/192-8416535-3018056
