Negative pulse generator with Arduino ????
Hello
Anyone knows if the arduino uno can produce negative pulse ???
Eg at 1khz
Anyone who knows us here to upload your code.
thanks
You can certainly output low-going pulses (5V -> 0V -> 5V) at about 1 kHz but you will need some external pulse shaping to get that funky shape. A capacitor can be used to round off the leading edge. A resistor will set how long it takes to reach zero. A diode will get the value back up to 5V quickly.
Are you trying to create negative voltages ?
The Arduino cannot do that directly, but there are ways it can be done , indirectly.
Here's the long and the short of it...
http://www.learningaboutelectronics.com/Articles/How-to-build-an-RC-type-differentiating-circuit
                          [color=blue][b]1N4148[/b][/color]
[b]Arduino Output Pin[/b]   [b]o[/b]———[color=blue][b]——|>|——[/b][/color]——?——————?—————[color=blue][/color]——[b]o[/b]   [b]Signal Output[/b]
        [b] [color=blue]10 K?   0.01 ?F [/color][/b]
        Gnd     Gnd
Calculated for 0.1 ms time constant: Online RC Time Constant Calculator - Gadget - Open Source Code
michinyon:
No negative voltages but negative pulse.
As the small photograph uploaded.
johnwasser:
Know a circuit that works properly?
dlloyd:
Arduino Output Pin   o—————|>|————?——————?———————o   Signal Output
        10 K?   0.01 ?F
        Gnd     Gnd
Calculated for 0.1 ms time constant: http://hughestech.com/rc_calculator/
Would try it. thanks
