I have a Nema 17 connected to the a4988 driver. When I have everything ready for operation, the engine makes an excessive noise and rotates uncontrollably and erratic. Try to change my Arduino board, bridge all my gnd, check the continuity of my cables, try another programming, change the driver, and none of that was the problem. Opinions??
Spanish:
Tengo un Nema 17 conectado al driver a4988. Cuando tengo todo listo para el funcionamiento, el motor hace un ruido excesivo y gira sin control y errático. Probe a cambiar mi placa arduino, puentear todos mis gnd, verificar la continuidad de mis cables, probar otra programación, cambiar el driver, y nada de eso era el problema. Opiniones??
