Hello, new to electronics here. I'm building a combined ph monitor + syringe pump setup such the stepper motor (NEMA 17) rotates and adds the syringe solution when measured pH crosses some threshold. I suspect I've blown a voltage regulator in the Arduino's (Uno Rev 3) power supply (NCP1117ST50T3G). However, I'm not sure if it's because the draw of the stepper motor overloaded it or if I happened to accidentally touch some pins together while working on it and caused a short. I've yet to attempt powering up the entire system at once so I wasn't expecting an overload but that doesn't necessarily mean much.
Could I ask for comments/don't-do-that's on the wiring diagram I've attached? This setup is a combination of a few things I found online so I don't have an exact circuit to go off. I thought about using a separate 9V power supply for just the stepper board but went against it, perhaps I should go back to that? Secondary question: if I don't, do I have to program what voltage to output via Vin when using an external power supply? Thanks for any feedback!
Parts are:
Arduino Uno Rev3, External power supply (12V, 2A), 4988 stepper motor driver and shield (9V, 1A), NEMA 17, Gravity analog pH meter and transmitter board (5V), SSD1306 OLED 0.96" (3.3V), and not pictured is a 1602 LCD shield (5V) that plugs directly into the pins of the Arduino which I couldn't figure out how to properly represent on the diagram.
