I rebuilt an older desktop CNC machine to run on Arduino/Grbl. Everything was working ok until it wasnt. The X axis will no longer switch directions. I did find a loose connection from a stepper driver to the motor. could that have blown only the Xdir pin? if i switch the motor to a different axis, it works as expected.
I have had this happen once before and I replaced the Arduino- which fixed it. I would like to know what is causing it, (the loose wire?) and I can just replace the chip.
I'm not great at writing arduino programs, but if there is a diagnostic I can run to test the pin, that would be great too.
thanks for the help!
