I've set up a NEMA 42 motor and a DM2282 driver via a breadboard, to my Arduino Uno.
Please see attached diagram for the setup.
The code I'm using is:
#include <AccelStepper.h>
// defines pins numbers
const int stepPin = 9;
const int dirPin = 8;
// Sets the two pins as Outputs
pinMode(stepPin,OUTPUT);
pinMode(dirPin,OUTPUT);
digitalWrite(dirPin,HIGH); // Enables the motor to move in a particular direction
// Makes 1000 pulses for making one full cycle rotation
for(int x = 0; x < 1000; x++) {
digitalWrite(stepPin,HIGH);
delayMicroseconds(500);
digitalWrite(stepPin,LOW);
delay(1000); // One second delay
digitalWrite(dirPin,LOW); //Changes the rotations direction
// Makes 1000 pulses for making two full cycle rotation
Can you tell why it isn't working?
The motor itself receives power so it's probably something in the digital pins or the wiring in the breadboard.
*The resistors are 330 Ohm
Thank you!
