Nema23 stepper motor vibrate when run
I have a nema23 stepper motor which I wanted to use when I installed it, it is causing a lot of vibration while moving due to which even the cutting tool is vibrating.stepper motor is 2.5amp or microstep 1.8. I have checked the connection as per the table. What should I do to eliminate the vibration? Please help me.
I moved your topic to an appropriate forum category @Dropside.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
If the vibration is in time with the motor stepping, then that is what stepping means. Step, stop, step, stop, etc.
Steppers can make noise, it depends on your code.
All stepper motors vibrate, and exhibit resonances at certain vibration frequencies.
The standard approach is to avoid step rates that match resonances in your setup (which amplify the vibration), and/or use microstepping. Experiment with the microstep division factor.
What RPM?
It varies, experiment to find out.
The use of rubber belts to transmit the power to the device will much reduce the transfer of vibrations.
Thank you for giving me your response.Will changing the micro step solve the problem? The setting I have made is shown in the picture. Can you tell me which micro setting will be the right micro step to reduce vibration?
