NEO-6m gives garbled output on serial monitor
I recently purchased a NEO-6M GT-U7 GPS off amazon to use with my arduino mega 2560. I tried to run the fullexample sketch included with the tinygps++ library, however the output on the serial monitor library comes out garbled. The GPS turns on and the red LED blinks. On the arduino, the builtin led turns on and the TX led blinks. I've done some research on this issue and possible answers could be that it simply is not able to fix to a satellite and I should wait longer to see if it connects. I've tried waiting up to 30 minutes for a connection but it does not seem to come. I also changed my baudrate to 9600 as info on amazon states. What could be causing the garbled output? Maybe my solder connections were not the best?
Attached is the code from the example and my garbled output.
code
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
   This sample code demonstrates the normal use of a TinyGPS++ (TinyGPSPlus) object.
   It requires the use of SoftwareSerial, and assumes that you have a
   4800-baud serial GPS device hooked up on pins 4(rx) and 3(tx).
static const int RXPin = 4, TXPin = 3;
static const uint32_t GPSBaud = 9600;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
  ss.begin(GPSBaud);
  Serial.println(F("FullExample.ino"));
  Serial.println(F("An extensive example of many interesting TinyGPS++ features"));
  Serial.print(F("Testing TinyGPS++ library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
  Serial.println(F("by Mikal Hart"));
  Serial.println(F("Sats HDOP  Latitude   Longitude   Fix  Date       Time     Date Alt    Course Speed Card  Distance Course Card  Chars Sentences Checksum"));
  Serial.println(F("           (deg)      (deg)       Age                      Age  (m)    --- from GPS ----  ---- to London  ----  RX    RX        Fail"));
  Serial.println(F("----------------------------------------------------------------------------------------------------------------------------------------"));
  static const double LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
  printInt(gps.satellites.value(), gps.satellites.isValid(), 5);
  printFloat(gps.hdop.hdop(), gps.hdop.isValid(), 6, 1);
  printFloat(gps.location.lat(), gps.location.isValid(), 11, 6);
  printFloat(gps.location.lng(), gps.location.isValid(), 12, 6);
  printInt(gps.location.age(), gps.location.isValid(), 5);
  printDateTime(gps.date, gps.time);
  printFloat(gps.altitude.meters(), gps.altitude.isValid(), 7, 2);
  printFloat(gps.course.deg(), gps.course.isValid(), 7, 2);
  printFloat(gps.speed.kmph(), gps.speed.isValid(), 6, 2);
  printStr(gps.course.isValid() ? TinyGPSPlus::cardinal(gps.course.deg()) : "*** ", 6);
  unsigned long distanceKmToLondon =
    (unsigned long)TinyGPSPlus::distanceBetween(
      gps.location.lat(),
      gps.location.lng(),
      LONDON_LAT,
      LONDON_LON) / 1000;
  printInt(distanceKmToLondon, gps.location.isValid(), 9);
  double courseToLondon =
    TinyGPSPlus::courseTo(
      gps.location.lat(),
      gps.location.lng(),
      LONDON_LAT,
      LONDON_LON);
  printFloat(courseToLondon, gps.location.isValid(), 7, 2);
  const char *cardinalToLondon = TinyGPSPlus::cardinal(courseToLondon);
  printStr(gps.location.isValid() ? cardinalToLondon : "*** ", 6);
  printInt(gps.charsProcessed(), true, 6);
  printInt(gps.sentencesWithFix(), true, 10);
  printInt(gps.failedChecksum(), true, 9);
  smartDelay(1000);
  if (millis() > 5000 && gps.charsProcessed() < 10)
    Serial.println(F("No GPS data received: check wiring"));
// This custom version of delay() ensures that the gps object
// is being "fed".
static void smartDelay(unsigned long ms)
  unsigned long start = millis();
  do
    while (ss.available())
      gps.encode(ss.read());
  } while (millis() - start < ms);
static void printFloat(float val, bool valid, int len, int prec)
  if (!valid)
    while (len-- > 1)
      Serial.print('*');
    Serial.print(' ');
    Serial.print(val, prec);
    int vi = abs((int)val);
    int flen = prec + (val < 0.0 ? 2 : 1); // . and -
    flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;
    for (int i=flen; i<len; ++i)
      Serial.print(' ');
  smartDelay(0);
static void printInt(unsigned long val, bool valid, int len)
  char sz[32] = "*****************";
  if (valid)
    sprintf(sz, "%ld", val);
  sz[len] = 0;
  for (int i=strlen(sz); i<len; ++i)
    sz[i] = ' ';
  if (len > 0)
    sz[len-1] = ' ';
  Serial.print(sz);
  smartDelay(0);
static void printDateTime(TinyGPSDate &d, TinyGPSTime &t)
  if (!d.isValid())
    Serial.print(F("********** "));
    char sz[32];
    sprintf(sz, "%02d/%02d/%02d ", d.month(), d.day(), d.year());
    Serial.print(sz);
  if (!t.isValid())
    Serial.print(F("******** "));
    char sz[32];
    sprintf(sz, "%02d:%02d:%02d ", t.hour(), t.minute(), t.second());
    Serial.print(sz);
  printInt(d.age(), d.isValid(), 5);
  smartDelay(0);
static void printStr(const char *str, int len)
  int slen = strlen(str);
  for (int i=0; i<len; ++i)
    Serial.print(i<slen ? str[i] : ' ');
  smartDelay(0);
Garbled output
FullExam****** ***** ***   ******** ****** ***   0     0         0
********** *********** **** ********** ******** **** ****** ****** ***** ***   ******** ****** ***   0     0         0
ȒI⸮c⸮rnFѐ⸮   mB⸮⸮⸮⸮
Why use software serial on a Mega with 3 extra hardware serial ports?
Connect the GPS TX to the Mega RX1 (pin 19) and run the following test code. GPS RX is not connected to anything. What do you get in serial monitor (baud set to 9600)?
//gps test
// connect GPS TX to Mega pin 19 (RX1)
   // Open serial communications
   Serial1.begin(9600);
   Serial.print("Mega up");
   if (Serial1.available())
      Serial.print(char(Serial1.read()));
I receive my gps coordinates
Good. That means you have good communication between the Mega and GPS.
Here is your code from the OP modified to use Serial1 instead of software serial. Set serial monitor baud rate to 115200 (it makes the screen flicker less).
   It assumes that you have a  9600-baud serial GPS device hooked up GPS TX to Mega pin 19 (RX1).
TinyGPSPlus gps;
  Serial1.begin(GPSBaud);
      gps.location.lat(),
      gps.location.lng(),
      LONDON_LAT,
      LONDON_LON) / 1000;
      gps.location.lat(),
      gps.location.lng(),
      LONDON_LAT,
      LONDON_LON);
  smartDelay(1000);
// is being "fed".
  do
    while (Serial1.available())
      gps.encode(Serial1.read());
  if (!valid)
    while (len-- > 1)
      Serial.print('*');
    Serial.print(' ');
      Serial.print(' ');
  smartDelay(0);
  if (valid)
  sz[len] = 0;
    sz[i] = ' ';
  if (len > 0)
    sz[len-1] = ' ';
  Serial.print(sz);
  smartDelay(0);
  if (!d.isValid())
    char sz[32];
    Serial.print(sz);
  if (!t.isValid())
    char sz[32];
    Serial.print(sz);
  smartDelay(0);
  smartDelay(0);
I was able to connect to the satellite and receive my info. Thank you for your help. Although I still feel I don't understand what my issue was? Was simply the softwareserial that was causing my issue?
I refer you to the software serial documentation.
Not all pins on the Mega and Mega 2560 support change interrupts, so only the following can be used for RX: 10, 11, 12, 13, 14, 15, 50, 51, 52, 53, A8 (62), A9 (63), A10 (64), A11 (65), A12 (66), A13 (67), A14 (68), A15 (69).
You used pin 4 for RX.
