Neo 6m Gps, Issue
Trying to setup Ublox Neo 6m gps module, but it doesn’t work, have used this code from tinygps master library will provide you with library link also
#include <SoftwareSerial.h>
#include <TinyGPS.h>
/* This sample code demonstrates the normal use of a TinyGPS object.
   It requires the use of SoftwareSerial, and assumes that you have a
   4800-baud serial GPS device hooked up on pins 4(rx) and 3(tx).
TinyGPS gps;
SoftwareSerial ss(4, 3);
static void smartdelay(unsigned long ms);
static void print_float(float val, float invalid, int len, int prec);
static void print_int(unsigned long val, unsigned long invalid, int len);
static void print_date(TinyGPS &gps);
static void print_str(const char *str, int len);
  Serial.print("Testing TinyGPS library v. "); Serial.println(TinyGPS::library_version());
  Serial.println("by Mikal Hart");
  Serial.println("Sats HDOP Latitude  Longitude  Fix  Date       Time     Date Alt    Course Speed Card  Distance Course Card  Chars Sentences Checksum");
  Serial.println("          (deg)     (deg)      Age                      Age  (m)    --- from GPS ----  ---- to London  ----  RX    RX        Fail");
  Serial.println("-------------------------------------------------------------------------------------------------------------------------------------");
  ss.begin(4800);
  float flat, flon;
  unsigned long age, date, time, chars = 0;
  unsigned short sentences = 0, failed = 0;
  static const double LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
  print_int(gps.satellites(), TinyGPS::GPS_INVALID_SATELLITES, 5);
  print_int(gps.hdop(), TinyGPS::GPS_INVALID_HDOP, 5);
  gps.f_get_position(&flat, &flon, &age);
  print_float(flat, TinyGPS::GPS_INVALID_F_ANGLE, 10, 6);
  print_float(flon, TinyGPS::GPS_INVALID_F_ANGLE, 11, 6);
  print_int(age, TinyGPS::GPS_INVALID_AGE, 5);
  print_date(gps);
  print_float(gps.f_altitude(), TinyGPS::GPS_INVALID_F_ALTITUDE, 7, 2);
  print_float(gps.f_course(), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
  print_float(gps.f_speed_kmph(), TinyGPS::GPS_INVALID_F_SPEED, 6, 2);
  print_str(gps.f_course() == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(gps.f_course()), 6);
  print_int(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0xFFFFFFFF : (unsigned long)TinyGPS::distance_between(flat, flon, LONDON_LAT, LONDON_LON) / 1000, 0xFFFFFFFF, 9);
  print_float(flat == TinyGPS::GPS_INVALID_F_ANGLE ? TinyGPS::GPS_INVALID_F_ANGLE : TinyGPS::course_to(flat, flon, LONDON_LAT, LONDON_LON), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
  print_str(flat == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(TinyGPS::course_to(flat, flon, LONDON_LAT, LONDON_LON)), 6);
  gps.stats(&chars, &sentences, &failed);
  print_int(chars, 0xFFFFFFFF, 6);
  print_int(sentences, 0xFFFFFFFF, 10);
  print_int(failed, 0xFFFFFFFF, 9);
  smartdelay(1000);
  unsigned long start = millis();
  do
    while (ss.available())
      gps.encode(ss.read());
  } while (millis() - start < ms);
  if (val == invalid)
    while (len-- > 1)
      Serial.print('*');
    Serial.print(' ');
    Serial.print(val, prec);
    int vi = abs((int)val);
    int flen = prec + (val < 0.0 ? 2 : 1); // . and -
    flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;
    for (int i=flen; i<len; ++i)
      Serial.print(' ');
  smartdelay(0);
  char sz[32];
  if (val == invalid)
    strcpy(sz, "*******");
    sprintf(sz, "%ld", val);
  sz[len] = 0;
  for (int i=strlen(sz); i<len; ++i)
    sz[i] = ' ';
  if (len > 0)
    sz[len-1] = ' ';
  Serial.print(sz);
  smartdelay(0);
  int year;
  byte month, day, hour, minute, second, hundredths;
  unsigned long age;
  gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);
  if (age == TinyGPS::GPS_INVALID_AGE)
    Serial.print("********** ******** ");
    char sz[32];
    sprintf(sz, "%02d/%02d/%02d %02d:%02d:%02d ",
        month, day, year, hour, minute, second);
    Serial.print(sz);
  smartdelay(0);
  int slen = strlen(str);
  for (int i=0; i<len; ++i)
    Serial.print(i<slen ? str[i] : ' ');
  smartdelay(0);
The output from the serial monitor looks like the image I have attached below and the library zip file is also attached below
and the connections are simple
vcc - arduino (3.3volt)
gnd - arduino (gnd)
rx - arduino (digital pin 3)
tx - arduino ( digital pin 4)
let me know if more details are required from my side.
Thanks
TinyGPS-master.zip (11.7 KB)
You do have the GPS outdoors ?
The don't work very well, if at all, indoors.
Oh, till now I am working indoors, where even GSM signal strength is weak,
Ok, will try keeping it outside and let you know the updates
Thank you
Tried outdoors, but still the same output, I read in datasheet that I should be powered on for 2 hours for the first time, what does it mean?
Everytime I power on gps, I should wait for 2 hours, or one time 2 hours is fine?
Does the datasheet say the GPS has an LED that indicates a fix ?
Most have such an LED and it will indicate a fix, all the GPS needs is power.
It can take a few minutes for a GPS to acquire its first fix.
Image embedded for our convenience:
Technique described here.
Next time, just copy the text from the Serial Monitor window and paste it into a code block (just like the sketch) so we can read it without squinting. :-/
According to that output, it looks like the baud rate is not correct. ublox NEO-6M GPS devices have a default baud rate of 9600, not 4800.
BTW, that example program is one of the worst. It prints too much information, and the smartDelay function is not smart.
Also, you should avoid using SoftwareSerial. SoftwareSerial is very inefficient, because it disables interrupts for long periods of time. This can interfere with other parts of your sketch or other libraries. It cannot send and receive at the same time. Read the NeoGPS Installation instructions for a list of better alternatives.
And because the NEO-6M is a 3.3V device, you need to be careful about connecting it to a 5V Arduino.
To verify that the device is connected correctly and that you have chosen the correct baud rate, try the simple echo test:
#include <NeoSWSerial.h>
NeoSWSerial gpsPort( 4, 3 );
  Serial.begin( 9600 );
  gpsPort.begin( 9600 );
  if (gpsPort.available())
    Serial.write( gpsPort.read() );
You should see NMEA sentences on the Serial Monitor window, like $GPGGA, $GPRMC, etc.
You might try NeoGPS. It's smaller, faster, more accurate and more reliable than all other GPS libraries. It comes with a diagnostic program, NMEAdiagnostic.ino. See the Troubleshooting page for instructions and other tips.
If you'd like to try it, NeoSWSerial, AltSoftSerial and NeoGPS are available from the Ardino IDE Library Manager, under the menu Sketch -> Include Library -> Manage Libraries.
Cheers,
/dev
