NEO-6M GPS module can not catch the fix...
I have a problem with the NEO-6M GPS module.
The module can not catch the fix. I even replaced a standard antenna on the BS-580
and then... nothing ... for an hour everything is outside the window, and after that time I have readings from the u-center as on the screen.
Any idea?
I will add that the SIM800 module caught the fix after 5 minutes even inside the room ....
So what happens when you take the GPS outside ?
Those are not very strong signals, so you do need to see if it gets a fix when the signals are better.
Did you buy the GPS from a reputable supplier or was it cheap on eBay ?
