Hi, I have moved my (working) Neo-6m GPS from a Uno (pins 2,3) to a Mega 2560 that has a 3.5" TFT touchscreen shield, therefore, I only have pins 22-53 accessible. I set my TX/RX pins as such...
bumpydog:
Is there an incompatibility issue I am unaware of?
The convention, and one which saves forum members time, is that if you want help with code, you post it.
So this is a pure guess, as we dont know the code you are using, but maybe you are using Software Serial for the GPS, in which case if you study the Software Serial reference, you will see that it wont work on those pins on a Mega.
Apologies for not showing the whole code. Yes, the GPS uses software serial and, as you state, those pins do not support change interrupts, only pins 50-53 (on that header). I changed to 52/53 and all works fine, thanks.
