NEO-6M has lock, but no Data being sent to Uno
Hey,
I am very new to this and have got a NEO-6M GPS. I have connected it to my arduino with 3.3V and RX 4 and TX 3. I am using Software Serial. I loaded in the satellite tracker example code from the TinyGPS++ Library. The GPS module LED stays off when first turned on. After w hile, or if put outside, it will start flashing, indicating it has a lock. However when I open serial monitor, it just comes up with a stream of “⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮”. And a few other arbitary characters. This leads me to believe there may be some encoding issue?
Thanks for the help!
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
   This sample code demonstrates how to use an array of TinyGPSCustom objects
   to monitor all the visible satellites.
   Satellite numbers, elevation, azimuth, and signal-to-noise ratio are not
   normally tracked by TinyGPS++, but by using TinyGPSCustom we get around this.
   The simple code also demonstrates how to use arrays of TinyGPSCustom objects,
   each monitoring a different field of the $GPGSV sentence.
   It requires the use of SoftwareSerial, and assumes that you have a
   4800-baud serial GPS device hooked up on pins 4(RX) and 3(TX).
static const int RXPin = 4, TXPin = 3;
static const uint32_t GPSBaud = 9600;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
  From http://aprs.gids.nl/nmea/:
  $GPGSV
  GPS Satellites in view
  eg. $GPGSV,3,1,11,03,03,111,00,04,15,270,00,06,01,010,00,13,06,292,00*74
      $GPGSV,3,2,11,14,25,170,00,16,57,208,39,18,67,296,40,19,40,246,00*74
      $GPGSV,3,3,11,22,42,067,42,24,14,311,43,27,05,244,00,,,,*4D
  1    = Total number of messages of this type in this cycle
  2    = Message number
  3    = Total number of SVs in view
  4    = SV PRN number
  5    = Elevation in degrees, 90 maximum
  6    = Azimuth, degrees from true north, 000 to 359
  7    = SNR, 00-99 dB (null when not tracking)
  8-11 = Information about second SV, same as field 4-7
  12-15= Information about third SV, same as field 4-7
  16-19= Information about fourth SV, same as field 4-7
static const int MAX_SATELLITES = 40;
TinyGPSCustom totalGPGSVMessages(gps, "GPGSV", 1); // $GPGSV sentence, first element
TinyGPSCustom messageNumber(gps, "GPGSV", 2);      // $GPGSV sentence, second element
TinyGPSCustom satsInView(gps, "GPGSV", 3);         // $GPGSV sentence, third element
TinyGPSCustom satNumber[4]; // to be initialized later
TinyGPSCustom elevation[4];
TinyGPSCustom azimuth[4];
TinyGPSCustom snr[4];
struct
  bool active;
  int elevation;
  int azimuth;
  int snr;
} sats[MAX_SATELLITES];
  ss.begin(GPSBaud);
  Serial.println(F("SatelliteTracker.ino"));
  Serial.println(F("Monitoring satellite location and signal strength using TinyGPSCustom"));
  Serial.print(F("Testing TinyGPS++ library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
  Serial.println(F("by Mikal Hart"));
  // Initialize all the uninitialized TinyGPSCustom objects
  for (int i=0; i<4; ++i)
    satNumber[i].begin(gps, "GPGSV", 4 + 4 * i); // offsets 4, 8, 12, 16
    elevation[i].begin(gps, "GPGSV", 5 + 4 * i); // offsets 5, 9, 13, 17
    azimuth[i].begin(  gps, "GPGSV", 6 + 4 * i); // offsets 6, 10, 14, 18
    snr[i].begin(      gps, "GPGSV", 7 + 4 * i); // offsets 7, 11, 15, 19
  // Dispatch incoming characters
  if (ss.available() > 0)
    gps.encode(ss.read());
    if (totalGPGSVMessages.isUpdated())
        int no = atoi(satNumber[i].value());
        // Serial.print(F("SatNumber is ")); Serial.println(no);
        if (no >= 1 && no <= MAX_SATELLITES)
          sats[no-1].elevation = atoi(elevation[i].value());
          sats[no-1].azimuth = atoi(azimuth[i].value());
          sats[no-1].snr = atoi(snr[i].value());
          sats[no-1].active = true;
      int totalMessages = atoi(totalGPGSVMessages.value());
      int currentMessage = atoi(messageNumber.value());
      if (totalMessages == currentMessage)
        Serial.print(F("Sats=")); Serial.print(gps.satellites.value());
        Serial.print(F(" Nums="));
        for (int i=0; i<MAX_SATELLITES; ++i)
          if (sats[i].active)
            Serial.print(i+1);
            Serial.print(F(" "));
        Serial.print(F(" Elevation="));
          if (sats[i].active)
            Serial.print(sats[i].elevation);
        Serial.print(F(" Azimuth="));
          if (sats[i].active)
            Serial.print(sats[i].azimuth);
        Serial.print(F(" SNR="));
          if (sats[i].active)
            Serial.print(sats[i].snr);
          sats[i].active = false;
}[/quote]
If your not seeing the startup message;
(and the rest)
In the serial monitor, that is not being caused by a problem with the GPS.
I do see these yes, it just follows with a constant stream of question marks and random characters.
Have you set the baudrate correct on both serial monitor as well as the code? If there is a mismatch, or a rate the board do not support, you might see this characters. In your code the serial output is set to 115200. Make sure this is also set in the serial monitor, or try changing both to 9600.
That's a rather complex program. To start with, just echo what you are getting from the GPS to Serial. No point trying anything further until you can confirm that's working.
jray204:
And the code you posted actually is the code you are using ?
If the baud rate for the serial monitor was wrong you would not be seeing "SatelliteTracker.ino"
No characters are read from the GPS and directly printed to serial monitor, so the GPS baud rate being wrong should not be the cause of the series of apparently corrupt characters.
tormods:
This solved it! I overlooked it and it was obvious, thank you so much for pointing it out. The original example came with two different baud rates and I thought the second one was set to 115200 for a certain reason, and that I should only change the 4800 to 9600. It works great now! :DD
jray204:
So the code you posted was not the code you were using ?
