neo-6m works with Uno, but not mega2560
I was trying to link the Neo-6m GPS with my Arduino mega2560, RX–>pin 16 (TX on arduino), TX → pin 17 (RX on Arduino), 5V, GND, used code example from the TinyGPS library.
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
This sample sketch demonstrates the normal use of a TinyGPS++ (TinyGPSPlus) object.
It requires the use of SoftwareSerial, and assumes that you have a
4800-baud serial GPS device hooked up on pins 4(rx) and 3(tx).
static const int RXPin = 17, TXPin = 16;
static const uint32_t GPSBaud = 4800;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
ss.begin(GPSBaud);
Serial.println(F(“DeviceExample.ino”));
Serial.println(F(“A simple demonstration of TinyGPS++ with an attached GPS module”));
Serial.print(F("Testing TinyGPS++ library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
Serial.println(F(“by Mikal Hart”));
// This sketch displays information every time a new sentence is correctly encoded.
while (ss.available() > 0)
if (gps.encode(ss.read()))
displayInfo();
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println(F(“No GPS detected: check wiring.”));
while(true);
void displayInfo()
Serial.print(F(“Location: “));
if (gps.location.isValid())
Serial.print(gps.location.lat(), 6);
Serial.print(F(”,”));
Serial.print(gps.location.lng(), 6);
Serial.print(F(“INVALID”));
Serial.print(F(" Date/Time: “));
if (gps.date.isValid())
Serial.print(gps.date.month());
Serial.print(F(”/"));
Serial.print(gps.date.day());
Serial.print(F("/"));
Serial.print(gps.date.year());
Serial.print(F(" “));
if (gps.time.isValid())
if (gps.time.hour() < 10) Serial.print(F(“0”));
Serial.print(gps.time.hour());
Serial.print(F(”:"));
if (gps.time.minute() < 10) Serial.print(F(“0”));
Serial.print(gps.time.minute());
Serial.print(F(":"));
if (gps.time.second() < 10) Serial.print(F(“0”));
Serial.print(gps.time.second());
Serial.print(F("."));
if (gps.time.centisecond() < 10) Serial.print(F(“0”));
Serial.print(gps.time.centisecond());
I got Location: INVALID.
I tried out the same GPS with UNO, using pin 4, 3 instead. It worked out fine.
I am new to Arduino and may have made some silly rookie mistakes.
Any suggestion helps.
Thanks!
forget softserial.
Mega has several hardware ports..
Thanks for the suggestion, Ny!
I tried using serial2,begin(), serial2.available(), etc, since connecting to pin16,17, but still got the same result. Any thoughts?
zxyallison:
post your new code in tags please
New code using Serial2
static const uint32_t GPSBaud = 9600;
TinyGPSPlus gps;
  Serial2.begin(GPSBaud);
  Serial.println(F("DeviceExample.ino"));
  Serial.println(F("A simple demonstration of TinyGPS++ with an attached GPS module"));
  Serial.println(F("by Mikal Hart"));
  while (Serial2.available() > 0)
    if (gps.encode(Serial2.read()))
      displayInfo();
    Serial.println(F("No GPS detected: check wiring."));
    while(true);
void displayInfo()
  Serial.print(F("Location: "));
    Serial.print(F(","));
    Serial.print(F("INVALID"));
  Serial.print(F("  Date/Time: "));
  Serial.print(F(" "));
    if (gps.time.hour() < 10) Serial.print(F("0"));
    if (gps.time.minute() < 10) Serial.print(F("0"));
    if (gps.time.second() < 10) Serial.print(F("0"));
    if (gps.time.centisecond() < 10) Serial.print(F("0"));
Are you getting an incorrect wiring error, or does your module just have no satellite fix?
do you have a steel roof?
is the antenna built into the module?
do you have an LED blinking at 1 pulse per second?
The most common cause of the GPS not reporting a valid fix, is trying to use it indoors.
The GPS should be outdoors with a good view of the sky.
Incidently the reason why softwareserial does not work on a Mega2560 is mentioned here;
GPS Troubleshooting
Power_Broker, Geek Emeritus and srnet
Thank you for your suggestions.
To answer your questions,
The antenna is linked with the Module.
I used the GPS outdoors, with a clear view of sky. The LED is blinking.
When I connect the GPS with Arduino Uno, it worked fine, and reported my lat and lon.
However, when I hooked it up with Mega, still outdoors on the same table as before, it reported Loation:Invalid.
Power_Broker is right. There was zero satellite available.
Any thoughts on how I can fix it?
Thank you so much!
