When I turn it on after it had a fix previously (hot boot?) it takes a long time until it gets a fix. I put the module outside and the fastest I have seen it make a fix was 5 minutes. It would often keep the fix for several minutes and then loose it again.
Is this normal? Expected? Do I have bad luck with my antenna? Or do I maybe need to get a better antenna?
The board I have is the "LilyGO TTGO T-Beam - LoRa 868MHz - NEO-M8N GPS - ESP32"
Just going to update here: The antenna was faulty. I got a new (tiny ceramic plate antenna) and it works great. I can even get a fix indoors. Kinda close to the window within minutes, further away from the window takes a bit of time...
