Hello, im using an arduino nano and a neo pixel string to create a project. What i am trying to do is have an led fade in and then stay on once it has reached the brightest value for good.
The code I have created works with the fade in but it seems to loop. Any ideas how to fix this?
class Strip
public:
uint8_t effect;
uint8_t effects;
uint16_t effStep;
unsigned long effStart;
Adafruit_NeoPixel strip;
Strip(uint16_t leds, uint8_t pin, uint8_t toteffects, uint16_t striptype) : strip(leds, pin, striptype) {
effect = -1;
effects = toteffects;
Reset();
void Reset(){
effStep = 0;
effect = (effect + 1) % effects;
effStart = millis();
struct Loop
uint8_t currentChild;
uint8_t childs;
bool timeBased;
uint16_t cycles;
uint16_t currentTime;
Loop(uint8_t totchilds, bool timebased, uint16_t tottime) {currentTime=0;currentChild=0;childs=totchilds;timeBased=timebased;cycles=tottime;}
Strip strip_0(1, 8, 1, NEO_GRB + NEO_KHZ800);
struct Loop strip0loop0(1, false, 1);
//[GLOBAL_VARIABLES]
//Your setup here:
strip_0.strip.begin();
//Your code here:
strips_loop();
void strips_loop() {
if(strip0_loop0() & 0x01)
strip_0.strip.show();
uint8_t strip0_loop0() {
uint8_t ret = 0x00;
switch(strip0loop0.currentChild) {
case 0:
ret = strip0_loop0_eff0();break;
if(ret & 0x02) {
ret &= 0xfd;
if(strip0loop0.currentChild + 1 >= strip0loop0.childs) {
strip0loop0.currentChild = 0;
if(++strip0loop0.currentTime >= strip0loop0.cycles) {strip0loop0.currentTime = 0; ret |= 0x02;}
else {
strip0loop0.currentChild++;
return ret;
uint8_t strip0_loop0_eff0() {
// Strip ID: 0 - Effect: Fade - LEDS: 1
// Steps: 22.86046511627907 - Delay: 43
// Colors: 2 (0.0.0, 255.0.0)
// Options: duration=983, every=1,
if(millis() - strip_0.effStart < 43 * (strip_0.effStep)) return 0x00;
uint8_t r,g,b;
double e;
e = (strip_0.effStep * 43) / (double)983;
r = ( e ) * 255 + 0 * ( 1.0 - e );
g = ( e ) * 0 + 0 * ( 1.0 - e );
b = ( e ) * 0 + 0 * ( 1.0 - e );
for(uint16_t j=0;j<1;j++) {
if((j % 1) == 0)
strip_0.strip.setPixelColor(j, r, g, b);
strip_0.strip.setPixelColor(j, 0, 0, 0);
if(strip_0.effStep >= 22.86046511627907) {strip_0.Reset(); return 0x03; }
else strip_0.effStep++;
return 0x01;
