How much time that gps will take to get lock with satellite.
And does this gps module will give exact location or not.
Can any one please answer my question.
Thanks in advance.
Where is your antenna located? That can affect satellite lock time.
And the location should be within a few meters of actual location.
anil801999:
Thanks in advance.
That depends on where you have the GPS and antenna. in a lot of cases you should get a fix within a couple of minutes.
The GPS may give a position accuracy of 5M or so, or it could be 50M or so, which it is depends on the location of the GPS and antenna.
Hi guys,
I just receive my neo6m gps and after testing all sorts of things I didn't make it work so I'm asking for help.
I tried "pur" serial output: doesn't give location
I tried TinyGPS++ Deviceexemple.ino with 9600 baudrate (as sayed in the product describtion). got that :
I tried NeoGPS NMEADiagnostic.ino and got that:
NMEAdiagnostic.INO: started
Looking for GPS device on AltSoftSerial( RX pin -1, TX pin -1 )
____________________________
Checking 9600 baud...
Received RMC
Received VTG
Received GGA
Received GSA
Received GSV
Received GLL
Received RMC
Received VTG
Received GGA
Received GSA
Received GSV
Received GLL
Received RMC
Received VTG
Received GGA
Received GSA
Received GSV
Received GLL
Received RMC
**** NMEA sentence(s) detected! ****
Received data:
244750524D432C2C562C2C2C2C2C2C2C2C2C2C4E2A35330D0A2447505654472C $GPRMC,,V,,,,,,,,,,N*53..$GPVTG,
2C2C2C2C2C2C2C2C4E2A33300D0A2447504747412C2C2C2C2C2C302C30302C39 ,,,,,,,,N*30..$GPGGA,,,,,,0,00,9
392E39392C2C2C2C2C2C2A34380D0A2447504753412C412C312C2C2C2C2C2C2C 9.99,,,,,,*48..$GPGSA,A,1,,,,,,,
2C2C2C2C2C2C39392E39392C39392E39392C39392E39392A33300D0A24475047 ,,,,,,99.99,99.99,99.99*30..$GPG
53562C312C312C30302A37390D0A244750474C4C2C2C2C2C2C2C562C4E2A3634 SV,1,1,00*79..$GPGLL,,,,,,V,N*64
0D0A244750524D432C2C562C2C2C2C2C2C2C2C2C2C4E2A35330D0A2447505654 ..$GPRMC,,V,,,,,,,,,,N*53..$GPVT
472C2C2C2C2C2C2C2C2C4E2A33300D0A2447504747412C2C2C2C2C2C302C3030 G,,,,,,,,,N*30..$GPGGA,,,,,,0,00
2C39392E39392C2C2C2C2C2C2A34380D0A2447504753412C412C312C2C2C2C2C ,99.99,,,,,,*48..$GPGSA,A,1,,,,,
Device baud rate is 9600
GPS data fields received:
Status,UTC Date/Time,Lat,Lon,DMS,Hdg,Spd,Alt,HDOP,Geoid Ht,Sats,Rx ok,Rx err,Rx chars,
0,,,,,,,,34454,,0,19,0,525,
** NMEAdiagnostic completed **
Does anyone as an Idea ?
P.S. : Ask if you need anything else.
