Declan
November 9, 2022, 6:29pm
1
I am using the NeoGPS library with a Quectel L80 GPS module.
The following code gets the fix with no problem.
while (gps.available( gpsSerial )) {
gps_fix fix = gps.read(); // save the latest
Serial.print("Latitude:");
Serial.println( fix.latitude(), 6);
Serial.print("Latitude String:");
String latTx = (String(fix.latitudeL()));
latTx = latTx.substring(1, 9);
Serial.println(latTx);
this works great and the Log is:
Latitude:-25.856170
Latitude String:25856170
I must now convert the value in the "Latitude String" to HEX in order to send via Sigfox.
So, "25856170" must be "018A88AA"
I have been banging my head and tried numerous examples from Granny Google, but all in vain.
Can anyone please point me in the right direction?
PaulRB
November 9, 2022, 6:36pm
2
char buffer[9];
sprintf(buffer, "%8LX", fix.latitudeL());
My best guess is:
char buffer[9];
unsigned long LatL = fix.latitudeL();
if (LatL < 0)
LatL = -LatL;
sprintf(buffer, "%08lx", LatL);
Serial.println(buffer);
Declan
November 10, 2022, 3:22am
4
This returns:
Latitude:-25.856647
Latitude String:25856646
Lat HEX: f09696bd
Where "f09696bd" is decimal value is 4036400829 and not 25856646
Declan
November 10, 2022, 3:27am
5
With:
char buffer[9];
if (LatL < 0)
LatL = -LatL;
Serial.print("Lat HEX: ");
I get the same result:
Latitude:-25.856864
Latitude String:25856863
Lat HEX: f0968e47
Where "f0968e47" is decimal value 4036398663 and not 25856863
PaulRB
November 10, 2022, 7:46am
6
I don't believe so. The "X" I used in the format string would return a hex representation where the letters "A"-"F" are upper-case, not lower-case as your result shows. So whatever code produced that result, I don't think it's the code I suggested.
The format string should have been "%08lX" to produce leading zeroes, I forgot the "0", and the "l" should be lower case and the "X" upper case.
@johnwasser spotted that sprintf() won't print negative hex numbers, so the code he suggested to check for negative values is important.
Declan
November 10, 2022, 8:49am
7
Yes, I saw that.
With both "I" and "X" in uppercase, I get nothing.
PaulRB
November 10, 2022, 8:50am
8
Declan:
I get nothing.
Nothing at all? Before, you were getting a value, but it was not the correct value. Now it prints nothing?
Please post the latest complete code.
Declan
November 10, 2022, 9:03am
9
With the following code, I change the value to a string and use substring to parse "25856175" from the original "( fix.latitude(), 6)".
I am not concerned about negative values as I take care of this on the backend.
I then need to change the resultant String "25856175" to a HEX string of "018A88AF".
Running this code:
char buffer[9];
sprintf(buffer, "%08lX", fix.latitudeL());
I get:
Lat HEX: F096ABB4
Where "F096ABB4" give me a decimal value of "4036406196".
This should be "018A886E" which is decimal value of "25856110"
Bearing in mind I am using the NeoGps library.
Prior to this I parsed the GPS data myself with:
// Get Latitude
char gpsLat[10];
//char latHex[9];
strncpy(gpsLat, gpsResponse + 17, 4);
strncpy(&gpsLat[4], gpsResponse + 22, 4);
gpsLat[8] = '\0';
sprintf(latHex, "%08lX", atol(gpsLat));
Serial.println(latHex);
delay(50);
and this worked fine
This is the correct output. You didn't put in 25856110, you put in -25856110 which is F096ABB4 in hex.
Declan
November 10, 2022, 9:47am
11
Yes, I see that - thanks
If I run:
char buffer[9];
sprintf(buffer, "%08lX", 25856110);
Output is:
Lat HEX: 018A886E
This is correct.
Do I need to change the String "25856110" to a Long or int?
Declan
November 10, 2022, 9:57am
12
Many thanks to all for your input.
This works:
long myLat = latTx.toInt();
Serial.print("myLat: ");
Serial.println(myLat);
char latHex[9];
sprintf(latHex, "%08lX", myLat);
Output is:
Latitude:-25.856161
Latitude String:25856161
myLat: 25856161
Lat HEX: 018A88A1
Which is correct.
Just looking back through the thread. I think this code which you used to remove the negative number didn't work:
if (LatL < 0)
LatL = -LatL;
You've stored the value in an unsigned long, which can't hold a negative number so when you check if LatL is less than zero it will always be false - an unsigned long can't be less than zero.
I think if you go back to this code but store it as a long then use the same method to convert negative number to positive it should work?
Declan:
Lat HEX: f0968e47
Oops! I should have used 'long', not 'unsigned long':
Because I used 'unsigned' the 'if (LatL < 0)' test fails and the negative number is not turned positive.
PaulRB
November 10, 2022, 1:48pm
15
Simplifying:
long myLat = abs(fix.latitudeL());
char latHex[9];
Declan
November 11, 2022, 3:29am
16
Many thanks - all sorted and have added above Simplifying code.
system
Closed
May 10, 2023, 3:29am
17
