Neomatrix.print() string error
I want to print a text on neomatrix using a string ( it works when i put the message directly in the neomatrix.print() line).
When i try to replace the text by a string, i get this simbol on neomatrix:
My code is :
#include <Adafruit_GFX.h>
#include <Adafruit_NeoMatrix.h>
//#ifndef PSTR
// #define PSTR // Make Arduino Due happy
//#endif
#define PIN 8
int b;
int c;
int d;
// MATRIX DECLARATION:
// Parameter 1 = width of NeoPixel matrix
// Parameter 2 = height of matrix
// Parameter 3 = pin number (most are valid)
// Parameter 4 = matrix layout flags, add together as needed:
//   NEO_MATRIX_TOP, NEO_MATRIX_BOTTOM, NEO_MATRIX_LEFT, NEO_MATRIX_RIGHT:
//     Position of the FIRST LED in the matrix; pick two, e.g.
//     NEO_MATRIX_TOP + NEO_MATRIX_LEFT for the top-left corner.
//   NEO_MATRIX_ROWS, NEO_MATRIX_COLUMNS: LEDs are arranged in horizontal
//     rows or in vertical columns, respectively; pick one or the other.
//   NEO_MATRIX_PROGRESSIVE, NEO_MATRIX_ZIGZAG: all rows/columns proceed
//     in the same order, or alternate lines reverse direction; pick one.
//   See example below for these values in action.
// Parameter 5 = pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(64, 8, PIN,
  NEO_MATRIX_BOTTOM  + NEO_MATRIX_RIGHT +
  NEO_MATRIX_COLUMNS + NEO_MATRIX_ZIGZAG,
  NEO_GRB            + NEO_KHZ800);
const uint16_t colors[] = {
  matrix.Color(255, 255, 0)};
  matrix.begin();
  matrix.show();
  matrix.setTextWrap(false);
  matrix.setBrightness(20);
  matrix.setTextColor(colors[0]);
char message = "Hello";
int x    = matrix.width();
int pass = 0;
  matrix.fillScreen(0);
  matrix.setCursor(x, 0);
  matrix.print(message);
  if(--x < -30) {  // nombre de caractères * 6
    x = matrix.width();
    if(++pass >= 1) pass = 0;
    matrix.setTextColor(colors[pass]);
 //   etoile();
  matrix.show();
  delay(15);
Thanks ,
Charles.
try like this:
String message = "Hello";
RV mineirin
Thank youuuuu god :smiley:
