Hi folks,
So I know it's probably a really stupid mistake in there somewhere, but I'm having a bit of trouble with a bit of code I wrote to make four sections of color rotate around a 24 pixel wheel.
This is the code:
#ifdef __AVR__
#include <avr/power.h>
#endif
#define PIN 6
int first = 0;
int second = 4;
int third = 8;
int fourth = 12;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(24, PIN, NEO_GRB + NEO_KHZ800);
uint32_t blue1 = strip.Color(0, 0, 255);
uint32_t blue2 = strip.Color(51, 51, 255);
uint32_t blue3 = strip.Color(0, 255, 255);
uint32_t yellow1 = strip.Color(255, 255, 0);
uint32_t yellow2 = strip.Color(255, 201, 51);
uint32_t yellow3 = strip.Color(255, 255, 51);
uint32_t orange1 = strip.Color(255, 128, 0);
uint32_t orange2 = strip.Color(255, 154, 0);
uint32_t purple1 = strip.Color(204, 0, 244);
uint32_t Purple2 = strip.Color(153, 0, 153);
uint32_t Purple3 = strip.Color(153, 51, 255);
// This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket
#if defined (__AVR_ATtiny85__)
if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
#endif
// End of trinket special code
strip.setBrightness(255);
strip.begin();
strip.show(); // Initialize all pixels to 'off'
colorWheel(15);
void colorWheel(uint8_t wait){
for(first<24){
if(second == 23){
second = 0;
if(third == 23){
third = 0;
if(fourth == 23){
fourth =0;
strip.setPixelColor(first, blue1);
strip.setPixelColor(second, yellow1);
strip.setPixelColor(third, purple1);
strip.setPixelColor(fourth, orange1);
first = first + 1;
second = second + 1;
third = third + 1;
fourth = fourth + 1;
strip.show();
delay(wait);
And the Errors are (yes I named it Four_score)
Four_Score.ino: In function 'void colorWheel(uint8_t)':
Four_Score:47: error: expected ';' before ')' token
Four_Score:73: error: expected primary-expression at end of input
Four_Score:73: error: expected ';' at end of input
Four_Score:73: error: expected ')' at end of input
Four_Score:73: error: expected statement at end of input
Four_Score:73: error: expected '}' at end of input
What I'm confused about is that the errors and the lines they're referencing make no sense. They talk about a missing semi-colon at 47 and I don't see anywhere I didn't put one.
Any help you guys can give would be greatly appreciated, Thanks!
