neopixel and a capacitor.
So I'm connecting a 5v neopixel, just a single one to my Arduino nano. Then someone told me I needed to have a capacitor for it, is that true?
I mean as far as I know, it's only good for whenever u have an external power source like a battery to somehow stabilize or stop a too big flow of power?
It is good practise to put a decoupling capacitor next to every digital chip. The neopixel is a digital chip plus a few LEDs.
But for just playing with only one, no problem to go without.
MorganS:
I’m going to solder everything together soon for a project, would it be wise to use one? I have a couple already, but I’m not sure of which one to use?
Just for one it will not matter, but if you must fit one then go for 10uF.
Grumpy_Mike:
Thank you very much for your answer. So there's no risks of not adding one?, when I'm only using a single pixel? :slight_smile:
No risk. The current draw of 60mA maximum is handled by the surface mount 0.1uF capacitor already attached to each LED section of a strip.
If the LED has not been cut from a strip and is just a surface mount or through hole version then I would add a 0.1uF ceramic capacitor across the powe lines as close to the LED as you can get.
