Hi there, I got a project with a midi-controlled neopixel-ring.
All working so far, but It got problems with fast switches from one animation-mode to the other.
It should behave like this:
midi-note 64 on: green pixel-animation
midi-note 64 off: no pixel-animation (by setting pixelColor = 0)
midi-note 66 on: green pixel-animation
midi-note 66 off: no pixel-animation (by setting pixelColor = 0)
If there is a fast switch from note 64 to note 66, the animation stops.
I guess the messages for note64-off and note66-on come at almost the same time and somehow the message to switch off the animation is faster.
My approach to solve that problem would be an if-statement in the „void OnNoteOff“-section.
Is it possible to do something like this:
case 64:
if (*note 66 is also off*) {
pixblockColor = 0;
Here is my full code:
// AdaFruit NeoPixel library
#define NR_OF_LED_CIRCLE 16
Adafruit_NeoPixel pixelCircle = Adafruit_NeoPixel(NR_OF_LED_CIRCLE, 23, NEO_GRB + NEO_KHZ800);
uint8_t offset = 0; // StartPosition of pixelCircle
uint32_t pixblockColor = 0; // Default color of pixelCircle (Black)
uint8_t pixblock = 4; // Size of rotating pixelbar
//Serial.begin(115200);
pixelCircle.begin();
pixelCircle.setBrightness(40);
usbMIDI.setHandleNoteOff(OnNoteOff);
usbMIDI.setHandleNoteOn(OnNoteOn) ;
usbMIDI.read(2); // Midi channel to read
for(int i=0; i<NR_OF_LED_CIRCLE; i++) {
uint32_t c = 0;
if(((offset - i) & 7) < pixblock) c = pixblockColor;
pixelCircle.setPixelColor( i, c); // First eye
pixelCircle.show();
offset++;
offset=millis()/100;
//MIDI READ
void OnNoteOn(byte channel, byte note, byte velocity) {
if (velocity > 0) {
switch (note) {
case 64:
pixblockColor = pixelCircle.Color(57, 230, 0); // animation green
pixblock = 7;
case 66:
pixblockColor = pixelCircle.Color(0, 128, 255); // animation blue
pixblock = 7;
void OnNoteOff(byte channel, byte note, byte velocity) {
switch (note) {
case 64:
pixblockColor = 0;
case 66:
pixblockColor = 0;
