Neopixel Lagging Loop
hi, my loop uses a rotary encoder to navigate a menu, then displays the info on a screen, after adding a neopixel my rotary encoder lags, if I turn the neopixel off I get the full response from the encoder back, is there a way I can give the rotary encoder priority, to stop the lag
  if (digitalRead(BypassFSW) == HIGH)
    if (current_patch == 0)
      pixels.setPixelColor(0, r0, g0, b0); // Yellow
    pixels.show();
    if (current_patch == 1)
      pixels.setPixelColor(0, r1, g1, b1); // Green
    pixels.show();
    if (current_patch == 2)
      pixels.setPixelColor(0, r2, g2, b2);  // Red
    pixels.show();
    if (current_patch == 3)
      pixels.setPixelColor(0, r3, g3, b3); // Grey
    pixels.show();
    if (current_patch == 4)
      pixels.setPixelColor(0, r4, g4, b4); // Blue
    pixels.show();
    if (current_patch == 5)
      pixels.setPixelColor(0, r5, g5, b5); // Magenta
    pixels.show();
    if (current_patch == 6)
      pixels.setPixelColor(0, r6, g6, b6); // Orange
    pixels.show();
    if (current_patch == 7)
      pixels.setPixelColor(0, r7, g7, b7); // Cyan
    pixels.show();
  if (digitalRead(BypassFSW) == LOW)
    pixels.setPixelColor(0, 0, 0, 0); // Off
    pixels.show();
  const uint16_t * palette = patch_colors[current_patch];
  if (myButton.rose() == true) {
    if (es == None) {
      es = Select;
      draw_selection(palette, selection, false);
    } else if (es == Select) {
      es = Change;
      // emphasize bar that is being edited
      draw_selection(palette, selection, true);
    } else if (es == Change) {
      es = None;
      if (changed[current_patch]) {
        bg_col = MARKED;
        draw_panel();
        draw_patch();             // Redraw the whole screen
      clear_selection(selection);
  int8_t dir = read_rotary();
  if (myButton.update() == true) {
    switch (myButton.event()) {
      // things to do if the button was held (Hold = Save)
      case (hold) : {
            save_current_patch();
            es = None;                               // Go to default mode
            rainbow(1);
            pixels.show();
  footswitch.update();
  // Encoder turned
  if (dir) {
    if (es == None) { // first movement activates Select mode
      es = Select;
      change_selection(palette, dir);  // Move selection
      //  bool fast = (fast_button.read() == HIGH);
      edit_patch(selection, -dir);       // Change parameter
  // Footswitch pressed
  if (footswitch.pressed()) {
    if (es == Select) {
      es = None;
    if (es != Change) {  // Patch change disabled during editing
      change_patch(1);
Your code is incomplete and does not compile.
Only call "pixels.show()" once for each iteration of "loop()".
    //pixels.setPixelColor(0, the_missing_color_array[current_patch]);
    if (current_patch == 0) pixels.setPixelColor(0, r0, g0, b0); // Yellow
    else if (current_patch == 1) pixels.setPixelColor(0, r1, g1, b1); // Green
    else if (current_patch == 2) pixels.setPixelColor(0, r2, g2, b2);  // Red
    else if (current_patch == 3) pixels.setPixelColor(0, r3, g3, b3); // Grey
    else if (current_patch == 4) pixels.setPixelColor(0, r4, g4, b4); // Blue
    else if (current_patch == 5) pixels.setPixelColor(0, r5, g5, b5); // Magenta
    else if (current_patch == 6) pixels.setPixelColor(0, r6, g6, b6); // Orange
    else if (current_patch == 7) pixels.setPixelColor(0, r7, g7, b7); // Cyan
    pixels.show();
If you use an array for colors, all the if and else would be a one liner..
You meant to use some brackets.
    if (current_patch == 4) {
      pixels.show();
For any real advice, please post the entire program and an adequate description of its functions.
a7
thanks guys, alto777's brackets fixed it
Yikes.
{ } braces
[ ] brackets
( ) parentheses
There is no excuse for ever using the wrong term. Sry.
And you don't need to call braces "curly". That is redundant.
a7
