I am trying to turn neopixel turn on, when PIR Sensor detect Motion and stay turned on for 1min after no motion is detected. I am newbee to Arduino and stuff. going throught codes avaiable I have come to the code shown below. the problem is PIR is detecting motion but LED is not turning on.
Pir is connected to PIN 7 and Neopixel to Pin 8
#define PIN 6
#define NUMPIXELS 14
Adafruit_NeoPixel pixels(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel strip = Adafruit_NeoPixel(50, PIN, NEO_GRB + NEO_KHZ800);
#define DELAYVAL 50
const int MOTION_SENSOR_PIN = 7;
int state = LOW;
int value = 0;
pinMode(MOTION_SENSOR_PIN, INPUT);
void loop(){
if (value == HIGH) {
for(int i=0;i<NUMPIXELS;i++){
pixels.setPixelColor(i, pixels.Color(0,222,0));
pixels.show();
delay(DELAYVAL);
else {
for(int i=0; i<NUMPIXELS; i++) {
pixels.setPixelColor(i, pixels.Color(0, 0, 0));
pixels.show();
You are testing whether the value variable has a value of HIGH but it is only ever set to zero (LOW) and never changes
Is something meant to change the value variable ?
I found this code online. but when even when I am using this code, pir is not detecting anything
// How many NeoPixels are attached to the Arduino?
#define PIN 6
#define NUMPIXELS 10
#define DELAYVAL 50
const int sensor = 2;
int estado = LOW;
int valor = 0;
pinMode (sensor, INPUT);
Serial.begin (9600);
strip.begin();
randomSeed(analogRead(0));
valor = digitalRead (sensor);
int r = random(255);
int g = random(255);
int b = random(255);
if (valor == HIGH) {
pixels.setPixelColor(i, pixels.Color(r,g,b));
pixels.show();
delay(DELAYVAL);
else {
pixels.show();
Is there anything, such as a pulldown resistor, keeping pin 2 LOW when the PIR is not activated or is it floating at an unknow value, perhaps HIGH, perhaps LOW ?
What do you see if you print the value of the valor variable ?
Does the PIR have its own timer that keeps its output on for a period after it is triggered ?
Just looking at the 'PIR' via SerialMonitor (left the neopixel stuff in there anyway) --
#define PIN 6
#define DELAYVAL 50
const byte MOTION_SENSOR_PIN = 7;
byte state = LOW;
byte result = 0;
Serial.begin(19200);
Serial.println("ok ok");
//pinMode(MOTION_SENSOR_PIN, INPUT);
result = digitalRead(MOTION_SENSOR_PIN);
if(result)
Serial.println("HI");
Serial.println("LO");
delay(50);
system
Closed
July 5, 2023, 3:17pm
6
