Neopixel Library error: `expected initializer before "pixels"`
EDIT: TL,DR I forgot a semicolon.
I am an Arduino noob and having difficulty figuring out the cause of a compilation error. I am able to run the neopixel example called "simple" on my Uno and I believe I am using the library very similarly in my code before but I keep getting the error pasted at the bottom of this post about expected initializer before "pixels" and highlighting the line:
Adafruit_NeoPixel pixels(NUMPIXEL, MATRIX_PIN, NEO_GRB + NEO_KHZ800);
I traced through the other lines mentioned and don't understand why this initialization doesn't appear accepted when it's almost the same as the neopixel library example. It's a global variable so it should also be in scope. I also tried using the format
Adafruit_NeoPixel pixels = Adafruit_Neopixel(NUMPIXEL, MATRIX_PIN, NEO_GRB + NEO_KHZ800);
but that didnt help
//neopixel stuff
#define NUMPIXEL 16
//pins and state
const byte BUTTON1_PIN = A5;
const byte BUTTON2_PIN = A3;
const int MATRIX_PIN = 11,
//global var
unsigned long last_reset_time = 0;
const unsigned long ONE_DAY = 10000UL; //86400000UL;  //1 day in milliseconds
  pixels.begin();
  pinMode(MATRIX_PIN, OUTPUT);
  pinMode(BUTTON1_PIN, INPUT_PULLUP);
  pinMode(BUTTON2_PIN, INPUT_PULLUP);
  //turnOn();
  //every 24 hours, reset LEDs to on
  if ((unsigned long) (millis() - last_reset_time) > ONE_DAY) {
    last_reset_time = millis();
    turnOn();
  if (digitalRead(BUTTON2_PIN) == LOW){
    for (int i=NUMPIXEL; i>NUMPIXEL/2; i--){
      pixels.setPixelColor(i, pixels.Color(0, 0, 0));
  if (digitalRead(BUTTON1_PIN) == LOW){
    for (int i=1; i<=NUMPIXEL/2; i++){
  pixels.show();
Error
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
habit_keeper_v2:10:19: error: expected initializer before 'pixels'
D:\app development\arduino\habit_keeper_v2\habit_keeper_v2.ino: In function 'void setup()':
habit_keeper_v2:17:3: error: 'pixels' was not declared in this scope
   pixels.begin();
D:\app development\arduino\habit_keeper_v2\habit_keeper_v2.ino:17:3: note: suggested alternative: 'yield'
   pixels.begin();
   yield
D:\app development\arduino\habit_keeper_v2\habit_keeper_v2.ino: In function 'void loop()':
habit_keeper_v2:30:5: error: 'turnOn' was not declared in this scope
     turnOn();
habit_keeper_v2:35:7: error: 'pixels' was not declared in this scope
D:\app development\arduino\habit_keeper_v2\habit_keeper_v2.ino:35:7: note: suggested alternative: 'yield'
       yield
habit_keeper_v2:41:7: error: 'pixels' was not declared in this scope
D:\app development\arduino\habit_keeper_v2\habit_keeper_v2.ino:41:7: note: suggested alternative: 'yield'
       yield
habit_keeper_v2:44:3: error: 'pixels' was not declared in this scope
   pixels.show();
D:\app development\arduino\habit_keeper_v2\habit_keeper_v2.ino:44:3: note: suggested alternative: 'yield'
   pixels.show();
   yield
exit status 1
Whoops
ugh im such an idiot. Is there a way for me to delete this thread so no one else has to waste their time? Thank you
BTDTGTTS
Let's leave it here to help anyone else that searches for the error and finds it
No.
The schadenfreude is strong.
(We've all been there)
