Neopixel/NeoMatrix/GFX help
I am trying to create a graphic equalizer using a MSGQE7 chip (Already built WORKING circuit) and a 5x7 Neopixel matrix (working). I am able to read the values coming in from the IC, but I cannot for the life of me get the Neopixel, neopixel matrix, or GFX libraries from Adafruit to play nice together. I have cobbled together (poorly) examples of other similar code in an attempt to get this working. I continue to receive this :
Graphic_Eq__EQ_WORKS_CODING_GFX.ino: In function 'void loop()':
Graphic_Eq__EQ_WORKS_CODING_GFX:72: error: expected initializer before '.' token
Graphic_Eq__EQ_WORKS_CODING_GFX:73: error: expected initializer before '.' token
Graphic_Eq__EQ_WORKS_CODING_GFX:74: error: expected initializer before '.' token
Graphic_Eq__EQ_WORKS_CODING_GFX:75: error: expected initializer before '.' token
Graphic_Eq__EQ_WORKS_CODING_GFX:76: error: expected initializer before '.' token
Graphic_Eq__EQ_WORKS_CODING_GFX:77: error: expected initializer before '.' token
Graphic_Eq__EQ_WORKS_CODING_GFX:78: error: expected initializer before '.' token
Graphic_Eq__EQ_WORKS_CODING_GFX:79: error: expected initializer before '.' token
I have tried to figure this out but cannot seem to get it going. Am I even close? Any guidance would be greatly appreciated!
the steaming pile that is my code is below:
#include <Adafruit_GFX.h>
#include <Adafruit_NeoMatrix.h>
#ifndef PSTR
 #define PSTR // Make Arduino Due happy
#endif
//define colors
#define black 0,0,0
#define blue (0,0,255)
#define cyan 0,255,255
#define gray 128,128,128
#define green 0,128,0
#define lime 0,255,0
#define magenta 255,0,255
#define maroon 128,0,0
#define navy 0,0,128
#define olive 128,128,0
#define purple 128,0,128
#define red 255,0,0
#define silver 192,192,192
#define teal 0,128,128
#define white 255,255,255
#define yellow 255,255,0
#define oranje 255,165,0
//Color Definitions
#define PIN 6
Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(5, 7, PIN,
  NEO_MATRIX_BOTTOM     + NEO_MATRIX_LEFT +
  NEO_MATRIX_COLUMNS + NEO_MATRIX_PROGRESSIVE,
  NEO_GRB            + NEO_KHZ800);
int analogPin = 0; // read from multiplexer using analog input 0
int strobePin = 2; // strobe is attached to digital pin 2
int resetPin = 3; // reset is attached to digital pin 3
int spectrumValue[7]; // to hold a2d values
int specChoke = 0;
const uint16_t colors[] = {
  matrix.Color(255, 0, 0), matrix.Color(0, 255, 0), matrix.Color(0, 0, 255) };
{ matrix.begin();
 pinMode(analogPin, INPUT);
 pinMode(strobePin, OUTPUT);
 pinMode(resetPin, OUTPUT);
 analogReference(DEFAULT);
int x = matrix.width();
 digitalWrite(resetPin, LOW);
 digitalWrite(strobePin, HIGH);
 digitalWrite(resetPin, HIGH);
 for (int i = 0; i < 7; i++)
 {matrix.fillScreen(0);
 digitalWrite(strobePin, LOW);
 delayMicroseconds(30); // to allow the output to settle
 spectrumValue[i] = analogRead(analogPin);
 specChoke = map(i, 0, 1023, 0, 7);
 if (spectrumValue[i]>=895) { void matrix.drawFastVLine(uint16_t x0, uint16_t y0, uint16_t 1, uint16_t 1); } else
 if (spectrumValue[i]>=767) { void matrix.drawFastVLine(uint16_t x0, uint16_t y0, uint16_t 1, uint16_t 1); } else
 if (spectrumValue[i]>=639) { void matrix.drawFastVLine(uint16_t x0, uint16_t y0, uint16_t 1, uint16_t 1); } else
 if (spectrumValue[i]>=511) { void matrix.drawFastVLine(uint16_t x0, uint16_t y0, uint16_t 1, uint16_t 1); } else
 if (spectrumValue[i]>=383) { void matrix.drawFastVLine(uint16_t x0, uint16_t y0, uint16_t 1, uint16_t 1); } else
 if (spectrumValue[i]>=255) { void matrix.drawFastVLine(uint16_t x0, uint16_t y0, uint16_t 1, uint16_t 1); } else
 if (spectrumValue[i]>=127) { void matrix.drawFastVLine(uint16_t x0, uint16_t y0, uint16_t 1, uint16_t 1); } else
 if (spectrumValue[i]>=0) { void matrix.fillScreen(0); }
Serial.println(spectrumValue[i]);
matrix.show();
Why are there two open curly braces before this statement? Why are you defining a function prototype if the statement is true?
I think its a lack of experience on my part. Any advice on where I should place void matrix.drawFastVLine(uint16_t x0, uint16_t y0, uint16_t 1, uint16_t 1) to make it work properly? Even pointing me to some resources on this would be a great help. What I am trying to do may not even be possible. My idea was to use MAP() to provide the line length variable eg.void matrix.drawFastVLine(uint16_t x0, uint16_t y0, uint16_t specChoke, uint16_t 1). That way the higher the value of the signal spectrumValue[i], the longer the line would be. I am having a hard time wrapping my head around how to work with the array coming from the graphic eq in relation to the lights.
It belongs in the library you copied it from.
Do you mean that you want to know where to call that function? If that is the case, where you have that statement now, remove the void and all the types:
   matrix.drawFastVLine( x0,  y0, 1, 1);
Then, presuming that you have initialized x0 and y0 correctly (which I doubt), this will draw a line. Whether it is the kind of line you want, or not, remains to be seen.
Awesome! I was looking at the situation the wrong way. Its not completely working, but I was able to move in the right direction (One light flashes like crazy, but does so in response to my voice) . Another question. I am beginning to think that the constant strobing required to get values from the Graphic Equalizer would leave me with some really "blinky" leds. Any idea for a way around this. I'm leaning towards using two arduinos. One to create the values from the MSGEQ7 and then pass the data over serial to another micro that talks to the lights. Is this overkill, lazy, or even practical for use?
Never mind, I figured out what to do. I mapped the signal value from the Graphic Eq. IC to each line I wanted drawn on the matrix between each strobe HIGH/LOW to the line length updated independently for each range of audible frequency. (I'll post the code tomorrow for any interested.) I didn't really understand function prototypes and their relationships to statements until this quest. Thanks for the guidance.
