Neopixel only works one time
I need some help with a school project. So basically, when I press the button I can control the leds with a potentiometer. When I don't press the button, I want to change to color of the neopixel with the potentiometer. The only problem is, the neopixel only works one time (when I send the code to my Arduino). I don't know how to solve the problem. Can somebody please help me?
Eindopdracht_versie5.ino (2.28 KB)
How is the button pin wired ?
Do you have a resistor keeping it at a known state when it is not pressed or is it floating at a voltage that may be HIGH or may be LOW and may even change ?
Google floating inputs and consider setting the pinMode() of the input to INPUT_PULLUP to activate the built in pullup resistor in the Arduino and wiring the pin to be taken LOW when the button is pressed
Thank you for your answer but I just fixed the problem! The mistake was in my code
Good news that you fixed it but my question is still relevant
