Neopixel panel - Laufschrift - 2. Zeile
Hallo! Habe Versucht mir nen Sketch zu schreiben bzw. zu kopieren um auf 2 Panels (je 2x32) einen unterschiedlichen Text zu schreiben.
Ideal wäre 1. Zeile als Laufschrift "LH A320-214 Simulator D-AIPB" und in der 2. Zeile "In Operaration" - blinkend.
#include <Adafruit_GFX.h>
#include <Adafruit_NeoMatrix.h>
#define PIN1 5
#define PIN2 6
// MATRIX DECLARATION:
// Parameter 1 = width of NeoPixel matrix
// Parameter 2 = height of matrix
// Parameter 3 = pin number (most are valid)
// Parameter 4 = matrix layout flags, add together as needed:
// NEO_MATRIX_TOP, NEO_MATRIX_BOTTOM, NEO_MATRIX_LEFT, NEO_MATRIX_RIGHT:
// Position of the FIRST LED in the matrix; pick two, e.g.
// NEO_MATRIX_TOP + NEO_MATRIX_LEFT for the top-left corner.
// NEO_MATRIX_ROWS, NEO_MATRIX_COLUMNS: LEDs are arranged in horizontal
// rows or in vertical columns, respectively; pick one or the other.
// NEO_MATRIX_PROGRESSIVE, NEO_MATRIX_ZIGZAG: all rows/columns proceed
// in the same order, or alternate lines reverse direction; pick one.
// See example below for these values in action.
// Parameter 5 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(64, 8, PIN1,
NEO_MATRIX_BOTTOM + NEO_MATRIX_RIGHT +
NEO_MATRIX_COLUMNS + NEO_MATRIX_ZIGZAG, //NEO_MATRIX_COLUMNS + NEO_MATRIX_ZIGZAG, NEO_MATRIX_BOTTOM + NEO_MATRIX_RIGHT
NEO_GRB + NEO_KHZ800);
const uint16_t colors[] = {
matrix.Color(255, 0, 0), matrix.Color(0, 255, 0), matrix.Color(255, 255, 0),matrix.Color(0, 0, 255), matrix.Color(255, 0, 255), matrix.Color(0, 255, 255), matrix.Color(255, 255, 255)};
matrix.begin();
matrix.setTextWrap(false);
matrix.setBrightness(5);
matrix.setTextColor(colors[0]);
int x = matrix.width();
int pass = 0;
matrix.fillScreen(0); //Turn off all the LEDs
matrix.setCursor(x, 0);
matrix.print(F("LH Simulator D-AIPB in Operation"));
if( --x < -175 ) { //-175
x = matrix.width();
if(++pass >= 8) pass = 0;
matrix.setTextColor(colors[pass]);
matrix.show();
delay(50);
Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(64, 8, PIN2,
matrix.begin();
int pass = 0;
matrix.print(F("In Operation"));
x = matrix.width();
matrix.show();
delay(50);
Vielleicht hat jemand ne Idee wie ich das realisieren könnte.
Danke
Gruss Peter
Hallo! Schade das niemand erfahrung hat mit diesem Pixel Panel.
Gruss Peter
