Neopixel status rgb convert to simple led
Hi
I try to revert from a neopixel code a status rgb led to a standard led with resistor on an output pin. I do understand it could start from this :
digitalWrite (PIN_LED, analogRead(A0) < myvoltlevel ? HIGH : LOW);
So currently i do have this and try to add 2 digitalwrite after, but i don't look to work...
strip.setPixelColor(LED_STATE,
      Analog_voltage() > 2.8 ? LED_COLOR_GREEN : LED_COLOR_RED);
// additional code put:
pinMode(Pin-led, OUTPUT);
int voltbat = digitalRead(Analog_voltage() > 2.8);
  if (Analog_voltage > 2.8)
    digitalWrite(Pin-led,HIGH);
    digitalWrite(Pin-led, LOW);
Thanks in advance for tips..
Can you explain what you expect to read from pin zero or pin one?
