alles klar bei folgenden Sketch geht zwar der erste Pixel an, der rest bleibt dunkel. Außerdem hat der 1 Pixel die falsche farbe....
#include <avr/pgmspace.h>
#define PIN 2
#define LED_QUANTITY 4
Adafruit_NeoPixel strip = Adafruit_NeoPixel(LED_QUANTITY, PIN, NEO_GRB + NEO_KHZ800);
//store the led values for fading
struct led{
byte hue;
byte sat;
byte light;
//load the sequence into PROGMEM because otherwise it overloads RAM
const byte ledSeq [16][LED_QUANTITY][3] PROGMEM = {
{{0x41, 0x81, 0x80},{0x00, 0x00, 0x00},{0x00, 0x00, 0x00},{0x00, 0x00, 0x00}},
{{0x2C, 0xE6, 0xEC},{0x00, 0x00, 0x00},{0x00, 0x00, 0x00},{0x00, 0x00, 0x00}},
{{0x01, 0xE6, 0xEC},{0x00, 0x12, 0x0E},{0x01, 0xE6, 0xEC},{0x01, 0xE6, 0xEC}},
{{0x00, 0x00, 0xFA},{0x06, 0xF5, 0xF2},{0x06, 0xF5, 0xF2},{0x06, 0xF5, 0xF2}},
{{0x00, 0x00, 0xFA},{0x10, 0xF5, 0xF2},{0x10, 0xF5, 0xF2},{0x10, 0xF5, 0xF2}},
{{0x18, 0x0A, 0xAC},{0x1F, 0xF5, 0xF2},{0x1F, 0xF5, 0xF2},{0x1F, 0xF5, 0xF2}},
{{0x00, 0x00, 0xFA},{0x27, 0xF5, 0xF2},{0x27, 0xF5, 0xF2},{0x27, 0xF5, 0xF2}},
{{0x18, 0x0A, 0xAC},{0x27, 0x7C, 0xEE},{0x27, 0x7C, 0xEE},{0x27, 0x7C, 0xEE}},
{{0x00, 0x00, 0xFA},{0x83, 0x7C, 0xEE},{0x83, 0x7C, 0xEE},{0x83, 0x7C, 0xEE}},
{{0x18, 0x0A, 0xAC},{0x9D, 0xF9, 0xD7},{0x9D, 0xF9, 0xD7},{0x9D, 0xF9, 0xD7}},
{{0x00, 0x00, 0xFA},{0x2C, 0xF9, 0xD7},{0x2C, 0xF9, 0xD7},{0x2C, 0xF9, 0xD7}},
{{0x18, 0x0A, 0xAC},{0x1B, 0xF9, 0xD7},{0x1B, 0xF9, 0xD7},{0x1B, 0xF9, 0xD7}},
{{0x00, 0x00, 0xFA},{0x03, 0xF9, 0xD7},{0x03, 0xF9, 0xD7},{0x03, 0xF9, 0xD7}},
{{0x18, 0x0A, 0xAC},{0x8B, 0xF9, 0xD7},{0x8B, 0xF9, 0xD7},{0x8B, 0xF9, 0xD7}},
{{0x00, 0x00, 0xFA},{0xA2, 0xF9, 0xD7},{0xA2, 0xF9, 0xD7},{0xA2, 0xF9, 0xD7}},
{{0x18, 0x0A, 0xAC},{0xA2, 0xF9, 0xD7},{0xA2, 0xF9, 0xD7},{0xA2, 0xF9, 0xD7}}
float fadefraction = .95; //adjust the fade out speed. typically .9-.99
int interval = 650; //the speed of the animation, lower is faster
//store colors for conversion from HSB
byte col[3] = {0,0,0};
//count loops
int counter = 0;
//current frame of the sequence
int frame = 0;
led myLeds[LED_QUANTITY];
pinMode( 3 , OUTPUT);
pinMode( 4 , OUTPUT);
pinMode( 0 , OUTPUT);
pinMode( 1 , OUTPUT);
strip.begin();
strip.show(); // Initialize all pixels to 'off'
analogWrite( 0 , HIGH );
delay( 500 );
analogWrite( 0 , LOW );
analogWrite( 1 , HIGH );
delay( 500 );
analogWrite( 1 , LOW );
analogWrite(3 , 255);
analogWrite(4 , 255);
delay( 1000 );
//step thru the sequence
if(frame < 16) {
if(counter%interval==0) {
for(int x = 0; x<LED_QUANTITY;x++) {
byte light = pgm_read_byte(&(ledSeq[frame][x][2])); //check the lightness value
if(light != 0x00) { //do not override with any black so that the fading can work
setPixelFade(x, pgm_read_byte(&(ledSeq[frame][x][0])), pgm_read_byte(&(ledSeq[frame][x][1])), light);
frame++;
}else{
frame=0;
//update the fading - you can increase the "5" for slower fading
if(counter%5==0)updateLeds();
strip.show();
counter++;
delay(1);
void updateLeds() {
for(int i = 0; i < LED_QUANTITY; i++) {
updateFade(i);
HSV_to_RGB(myLeds[i].hue, myLeds[i].sat, myLeds[i].light);
strip.setPixelColor(i, col[0], col[1], col[2]);
void setPixelFade(int m, byte hues, byte saturation, byte lightness) {
myLeds[m].light = lightness;
myLeds[m].hue = hues;
myLeds[m].sat = saturation;
void updateFade(int g) {
if(myLeds[g].light < 2) { //if the lightness is really low, set it to 0 to shut it all the way off
myLeds[g].light = 0;
else {
myLeds[g].light *= fadefraction;
//code to convert HSB to RGB
void HSV_to_RGB(float h, float s, float v)
int i;
byte r, g, b;
float f,p,q,t;
s /= 255;
v /= 255;
if(s == 0) {
// Achromatic (grey)
r = g = b = v*255;
col[0] = r;
col[1] = g;
col[2] = b;
return;
h /= 60; // sector 0 to 5
i = h;
f = h - i; // factorial part of h
p = v * (1 - s);
q = v * (1 - s * f);
t = v * (1 - s * (1 - f));
switch(i) {
case 0:
r = 255*v;
g = 255*t;
b = 255*p;
case 1:
r = 255*q;
g = 255*v;
b = 255*p;
case 2:
r = 255*p;
g = 255*v;
b = 255*t;
case 3:
r = 255*p;
g = 255*q;
b = 255*v;
case 4:
r = 255*t;
g = 255*p;
b = 255*v;
default:
r = 255*v;
g = 255*p;
b = 255*q;
col[0] = r;
col[1] = g;
col[2] = b;
return;
